Old 01-23-2016, 03:17 PM   #1
ClarityCamaro
ClarityCamaro's Avatar
Drives: 2013 black zl1
Nitrous or ported heads/cam
I was curious to know... it seems to me, nitrous is getting safter and Safter. With that said, I was about to order the works for my Camaro zl1... The blower plate system from nitrous outlet. Along with the pressure gauge, bottle heater, purge kit, lingenfilter timing retard, progressive controller, and a dedicated fuel cell. For around $3500. With that said. What do you guys think? Nitrous or ported heads and a cam.
ClarityCamaro is offline   Reply With Quote
Old 01-23-2016, 03:24 PM   #2
flyer08
Drives: 2010 2SS/RS
On a zl1 id rather have a cam. I do my know how well your heads flow if they even need done
flyer08 is offline   Reply With Quote
Old 01-23-2016, 04:40 PM   #3
ClarityCamaro
Just because? And I have heard of these ls3 heads. Heard they were beasts
Old 01-23-2016, 05:07 PM   #4
supergt99
supergt99's Avatar
Drives: 2013 Camaro SS 1LE
What's your power goal?
supergt99 is offline   Reply With Quote
Old 01-23-2016, 05:30 PM   #5
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Power goals? What do you use the car for? Current mods?
Hp per $$ the nitrous wins and will be an absolute monster on a big shot. If going the cam route I'd look into porting blower/snout better gains to be had over heads and less labor/hassle
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 01-23-2016, 06:57 PM   #6
gnturboray
gnturboray's Avatar
Drives: SIM 2010 2SS/RS LS3 LPE750
*Safer
gnturboray is offline   Reply With Quote
Old 01-23-2016, 07:02 PM   #7
flyer08
Drives: 2010 2SS/RS
If it was me Id want the cam because it's always there. The nitrous is nice when you need it but its the same as FI vs nitrous. Do you want quick burst or all the time fun? For me I decided to stay N/A and go nitrous. But If I was in Zl1 already supercharged Id take a cam all day.
Old 01-23-2016, 07:20 PM   #8
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
Do both cam and nitrous it will be a monster
Ported intake manifold and throttle body kooks 2" headers no cats
Fast6.3 is offline   Reply With Quote
Old 01-24-2016, 08:18 AM   #9
BlueN20Camaro
Banned
Drives: 1LE LS3
Are you also getting it for the Viper ? Did you already get your 20K motor build done? Install all the subframe bolts you were missing ? Need to do all that before nitrous build.
BlueN20Camaro is offline   Reply With Quote
Old 01-24-2016, 12:04 PM   #10
damian559
damian559's Avatar
Drives: 2015 1SS, 1LE, Recaro, NPP
This guy is such a troll. Don't even bother trying to help him.
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor)
647 RWHP 723 RWTQ (150 Shot)
12.1 @ 117 (Motor)
11.7 @ 129 (Nitrous)
Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports
Youtube Channel:
Click Here
damian559 is offline   Reply With Quote
Old 01-24-2016, 04:06 PM   #11
ClarityCamaro
I wish they would ban him already. Anyway. Going with the nitrous setup. I will post hp numbers when it's in and installed. Going with the blower plate kit from nitrous outlet. Is a window switch essential? I talked to nitrous outlet, and they told me I had everyth needed. Which was 3500. That was with everything I included in the original post. Sound right?
Old 01-24-2016, 04:17 PM   #12
fif_gen_powa
Progressive controller should have rpm window switch built in, which one is it?
8.3@164
Old 01-24-2016, 04:39 PM   #13
ClarityCamaro
It's the mini 2 stage progressive control from nitrous outlet.
Old 01-24-2016, 05:03 PM   #14
flyer08
Drives: 2010 2SS/RS
You'll be good with the mini
