Old 01-23-2016, 09:10 PM   #1
bbentley14
Drives: 2015 camaro 1ss
About to start my lsa install in a week or two any input welcome thanks
its a l99 car bought the lsa blower these are the plans unless I change my mind im ordering the cam monday. Any input would be helpful thanks
1. pending ,Either 2.3 or 2.55 pulley
2. pending brian tooley stage 2 cam
3. bought jlt cold air
4.bought obx 1 7/8 long tubes
5. bought snow performance stage 1 water/meth kit
6. bought 80lb injectors
7.pending kenne bell boost a pump or zl1 fuel pump?
bbentley14 is offline   Reply With Quote
Old 01-24-2016, 05:08 AM   #2
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
What kind of power are you trying to make out of your LSA?
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 01-24-2016, 05:56 AM   #3
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Go with the 2.55, the 2.38 will slip too much.
Just the zl1 pump with the adm fpcm will work.
Yes to the cam.
ttshovel is offline   Reply With Quote
Old 01-24-2016, 08:06 AM   #4
supergt99
supergt99's Avatar
Drives: 2013 Camaro SS 1LE
We need to know this question first
supergt99 is offline   Reply With Quote
Old 01-24-2016, 08:20 AM   #5
bbentley14
My goal is 650
Old 01-24-2016, 07:08 PM   #6
hammdo
'It's an experiment'
hammdo's Avatar
Yes to the cam.
What he said...
Proven to work. I've seen many with BTR PD Stage 3 plus your list make that all the time. Stage 2 should get you there. Don't forget, if you pulley down, think about cooling needs...
-Don
747 RWHP 794 RWTQ
Old 01-24-2016, 08:30 PM   #7
bbentley14
I want to do the sTage 3 btr pd cam but my converter is stock I've heard it work I've heard it don't so sorta leary about it
Old 01-24-2016, 08:53 PM   #8
supergt99
supergt99's Avatar
When in doubt go 1 size smaller on the cam. But sounds like a healthy setup. What did btr say about it?
Old 01-24-2016, 09:07 PM   #9
flyer08
Drives: 2010 2SS/RS
Get a circle d stall and you'll be good
flyer08 is offline   Reply With Quote
Old 01-24-2016, 09:18 PM   #10
bbentley14
Don't want to pull the Trans out just yet
Old 01-24-2016, 09:42 PM   #11
ttshovel
ttshovel's Avatar
Don't be worried about the stock converter. My buddy has a g8 gt with stock converter on a high compression 408 with the btr stage 4 ls3 cam. This is temporary until he can afford a nice converter. Drives just fine
