Old 01-25-2016, 06:21 PM   #1
bbentley14
Drives: 2015 camaro 1ss
So far on my lsa build. any input welcome
Ok i have a 15 ss l99. so far i have bought
1. lsa complete kit
2. 2.50 pulley
3. long tube 1 7/8
4. jlt cold air
5. btr pd stage 3 blower cam kit
6. Snow Performance Stage 1 kit
7. 80lb injectors.
I still need a fuel pump or would a boost a pump do the job? What kind of power do you think it should make? Thanks for any input
bbentley14 is offline   Reply With Quote
Old 01-25-2016, 06:50 PM   #2
cc-rider
Drives: 2010 Camaro SS
You absolutely should get a fuel pump. Blower + headers + cam will put you out of range of that stock pump. BAP doesn't do much on these cars due to the FPCM controlling voltage of the pump. I would recommend the ZL1 pump with the ADM FPCM. You can regularly find these in the classified section. Can usually pick up both for $300-$400 range. It's by far the most value for your dollar for a build like this.
Cool build! Good luck!
cc-rider is offline   Reply With Quote
Old 01-25-2016, 07:14 PM   #3
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
As it turns out, I have my ZL1 fuel pump & basket for sale from my car it came out with 8k miles on it. Let me know if you'd like to pick it up!
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
