Old 01-25-2016, 10:10 PM   #1
ADM PERFORMANCE
Drives: Anything I want
ADM Pulleys by Z Industries
ADM Performance, LSAConversion.com and Z06 Parts Inc. are proud to announce our 2016 line up of
Supercharger Pulleys by Z Industries and ADM Performance.
ADM Performance called upon Drew Zimmer and his father to manufacturer our new Premium line of
LSA, LT4,LS9, LSA Conversion and Magnusun Multi piece supercharger Pulleys .
Our new lineup will showcase these new benefits of the previous models:
GRIPTEC® MICRO
GipTec® Micro is a micro machining process. Our micro machining capabilities are near limitless and we apply our technology to give the target component the desired friction coefficient that optimizes the safest most aggressive gripping force possible. Our multidirectional machined ridges and valleys offer up more than just maximum gripping force they also act as escape ducts for trapped air and debris further helping in the mating of the target surface and belt. Patent Pending
Belt slip is a very common issue on supercharged components. In fact some units cranking out as much as 14-16 psi can take up to 200hp to drive. Often the drive systems are plagued with slippage issues and builders find themselves moving to noisy cog systems, where belts have shorter life spans, are difficult to find at just any parts store and they can create more heat through the frictional movement of the cogs.
Belt slip isn't always noticeable. Often belt slip is noticed when the system squeals, squeaks or boost falls off. Did you know that naturally the belt can slip a very small percentage even on NA vehicles, one major factor to belts wearing. Belt wrap does play a key factor in minimizing belt movement but when it comes to driving a supercharger is hard to fully eliminate with just surface contact. Systems runing 3.4 upper pulleys can see as much as a 1.5 psi gain when matching size for size puleys.
Whether you are running 6 psi or 20+ psi you are slipping if you are not running GripTec®
Pro's to using GripTec®
• Increased boost and supercharger performance size for size pulley
• Reduce or eliminate belt slippage on the applied component
• Increase belt life from not slipping over and over again
• Eliminate belt squeaks common when shifting hard
Con's
• To much boost for current engine tune. Adjustment may be required.
About ZPE
ZPE Inc. was founded in 2013 but is no stranger to the automotive world. Our parent company Z-Industries was founded in 1984 and Incorporated in 1987. Z-Industries Inc. offers advanced tuning and emissions services to the aftermarket and OEM industry. ZPE offers advanced engineering solutions for applications in both the automotive and the machinery industry. Our new found love for designing and patenting has brought several new technologies to the automotive and machine industry with more to come. Our commitment to our customers is to provide the highest quality components and service possible. Our standards of manufacturing are the highest possible and it shows in everything from the designs and quality of our parts to our custom packaging. We want to offer a quality that just doesn't exist in the performance world outside of ZPE, which is why we will continue to seek and develop new solutions and parts for years to come.
Andrew Zimmer
President
ZPE Inc.
ADM PERFORMANCE is offline   Reply With Quote
Old 01-28-2016, 09:36 AM   #2
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
I appreciate the attention to detail given to these products.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 01-30-2016, 10:41 PM   #3
Scuzz
Scuzz's Avatar
Drives: 2012 Camaro SS
Andy is this also for the heartbeat? And would it be beneficial for my build?
2012 Camaro SS Automatic
AGP Twin Turbo LSX427 / ADM Magic / 4L80
“1360 Rwhp 1225 Rwtq 25 lbs of boost”
Scuzz is offline   Reply With Quote
Old 02-01-2016, 06:59 AM   #4
ADM PERFORMANCE
Yes it would help.
Old 02-01-2016, 11:39 AM   #5
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
Do any of these work on the Maggie 2300 setups?
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq
fldrummer is offline   Reply With Quote
Old 02-01-2016, 04:25 PM   #6
VASTREETRACER
Drives: 2023 Camaro SS 1LE on order
I have a whipple 2.9 on my 2010 as with a 3.625 pulley. Bad slip issues. I've been told I need a 10 rib setup to fix the slippage issues. Problem is they all seem to be 2k plus for a complete system. Is this a complete system? And is it more cost friendly?
2017 Camaro SS 50th anniversary, I sold it but 2010 Camaro SS, whipple, cam, full bolt ons and full exhaust made 739/656 RWHP/TQ on 93 pump gas
VASTREETRACER is offline   Reply With Quote
Old 02-02-2016, 07:06 AM   #7
ADM PERFORMANCE
Yes we sell them for magnasun 2300 jackshaft sytle superchargers.
2.8" , 3.1", 3.4",3.6"
$129.00
Old 02-02-2016, 07:22 AM   #8
swiftkart
swiftkart's Avatar
Drives: 2010 SS/RS LS3 M6
$129.00
Are they the current 4 bolt style or do we need to purchase your new designed 10 bolt hub adapter to get them?
swiftkart is offline   Reply With Quote
Old 02-02-2016, 07:30 AM   #9
ADM PERFORMANCE
They will bolt directly to you current 4 bolt hub. These are Magnasun direct replacements.
Old 02-02-2016, 07:32 AM   #10
ADM PERFORMANCE
Whipple is a very large supercharger,it requires a very good belt system. 10 rib would be recommended in my opinion.
Old 02-13-2016, 04:02 PM   #11
MarioSS
MarioSS's Avatar
Drives: 2010 Camaro SS (RS LS3)
$129.00
I guess no love for the new SLP TVS2300? It's the 5 bolt
Sent from my Nexus 6P using Tapatalk
MarioSS is offline   Reply With Quote
Old 02-14-2016, 04:59 AM   #12
2010SSRSM6
2010SSRSM6's Avatar
8 ribs available for the jackstaff Maggie's yet?
Old 02-15-2016, 06:28 PM   #13
swiftkart
swiftkart's Avatar
I 2nd this, I forgot to ask when I asked about the 4 bolt design, I need a 8 rib 3.4, Thanks.
Old 02-15-2016, 10:47 PM   #14
ADM PERFORMANCE
Ok
Hang tight.....Answer is coming soon
