Old 01-26-2016, 11:19 AM   #1
Dasilva Motorsports
Dasilva Motorsports's Avatar
Drives: 2015 1LE
Announcement : Dasilva Motorsports - Exclusive Mantic Clutch Distributors for Canada
We are very excited to announce that Dasilva Motorsports is your exclusive Mantic Clutch Distributor for all of Canada .
Twin Disc 9000 Series C5 Camaro kits complete with flywheel and slave are just $2399.00
The key to the 9000 series (Organic) is street driveability. This kit includes sprung center cushioned organic discs. Fitted with anti rattle springs on the intermediate plate, a unique feature of the 9000 series the kit offer better than OE engagement and pedal feel whilst still providing a higher torque capacity. Mantic 9000 series clutches are twin disc, 9” (225mm) diameter modular clutches that are designed for high performance cars or track use. Mantic 9000 series are low MOI (Moment of Inertia) clutches that offer a level of performance not only superior to a single disc unit, but also allow you to select options that best suit you. All 9000 series clutches are made with premium quality materials designed to perform and last the distance. Offering up to 605ft lbs (820nm) of torque drive capability, (Note: Mantic Torque capacity figures include a 30% safety margin. Other manufacturers may not include this safety margin in their torque capacity ratings and quote theoretical capacities. In this case they would rate this clutch as having a torque capacity of approx 900ft lbs.)
Clutch Diameter 9.0"
Rated Torque (ft lbs) 607 ft lbs (820Nm)
Disc Spline 1 1/8" (29.5mm)
Disc No. Teeth 26
Disc Type Sprung Centre Cushioned
Disc Material Organic
Throwout Bearing No
Concentric Slave Cylinder including Bearing Yes
Alignment Tool Yes
Pilot Bush No
Flywheel Included Yes
Hardware Included Yes
Fitting Instructions Yes
These bullet proof clutch kits made in Australia are now available Exclusively from Dasilva Motorsports and participating dealers across Canada .
If you are a legitimate automotive performance business within Canada and would like to become a stocking dealer please contact us @
info@dasilvamotorsport.com
Dasilva Motorsports is offline   Reply With Quote
