Old 01-26-2016, 04:31 PM   #1
SSCamaroLover
Drives: Camaro
2011 Camaro 1000HP Dyno Water Methanol Injection
Just found this video - Turn up the speakers!
Camaro SS
• RMCR 7.0L LSX Racing Short Block
• Trick Flow 255cc LS3 Heads
• RMCR Custom Ground Camshaft
• ARP Head & Main Studs w/ Cometic Gaskets
• Melling Oil Pump
• Vortech V-7 YSiB Supercharger w/ 50mm Cog Drive around 20lbs of boost
• RMCR Dual Fuel Pump System w/ 1000cc Injectors
• Snow Dual Nozzle Staeg 2 Water Meth System
• Centerforce DYAD Clutch
• RPM Level VI Transmission w/ SFI Bell Housing
• DSS 9" Conversion
• BMR Suspension
• GM ILE Racing Wheels
• RPM 6 Point Roll Bar
SSCamaroLover is offline   Reply With Quote
Old 01-26-2016, 04:48 PM   #2
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Odd first post and video link isn't working.
Old 01-26-2016, 06:47 PM   #3
SSCamaroLover
Drives: Camaro
It's Fixed - Not a Guru - Sorry
Old 01-26-2016, 09:10 PM   #4
Big-T
Drives: 2014 2SS
In my experience, 100% meth is always better than a water mix. Good numbers, though!
Big-T is offline   Reply With Quote
Old 01-26-2016, 09:16 PM   #5
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
Welcome to the site sscamarolover
Moreair1 is offline   Reply With Quote
Old 01-26-2016, 10:28 PM   #6
D3R3K
Sittin side ways
D3R3K's Avatar
Drives: 2010 2SS/RS IOM
Is that your car in the video?
850+hp club member
Procharger F1-A
D3R3K is offline   Reply With Quote
Old 01-27-2016, 09:02 AM   #7
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
For all out power, yes. For safety, no
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 01-27-2016, 12:51 PM   #8
SSCamaroLover
Drives: Camaro
Thanks for the welcome Moreair 1
No this isn't my car, I wish. A friend of mine is tied to this dyno shop some how and made me aware of this video.
Old 01-27-2016, 03:24 PM   #9
Slowhawk
Drives: 1999 Trans Am
Looks pretty legit. My personal car ran 93 and methanol. Made well over 1000rwhp and did roughly 100 passes at the track 5.1- 5.2's in the 1/8th.
Slowhawk is offline   Reply With Quote
Old 01-27-2016, 03:55 PM   #10
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
Water and meth allowed for 6 degrees more timing... pretty good gains in the end.
RealQuick is offline   Reply With Quote
Old 01-27-2016, 04:44 PM   #11
hillshooter
Drives: 2015 Camaro SS commemorative
Great video. How legit is this though? thats a huge increase with just 6 degrees of timing? I am running 10 pounds of boost and I know my tuner had to pull timing out, so how dumb am I right now not having a meth injection kit?
hillshooter is offline   Reply With Quote
Old 01-27-2016, 08:09 PM   #12
Unreal
Drives: 2006 Z06
~15rwhp per degree is fairly normal.
Would like to see actual numbers since car is way up in elevation. FI and high elevation always inflates numbers.
Nick
Corvette Z06 -1200ish rwhp
Old 01-27-2016, 08:39 PM   #13
Big-T
Drives: 2014 2SS
I would argue meth is much safer than water.. you'd be hard pressed to hydrolock a motor with meth.
Old 01-29-2016, 12:04 PM   #14
SSCamaroLover
Drives: Camaro
I also questioned the elevation and was told it was tuned for Sea Level to make it legit. I got a 5th Gen with a new Vortec and I've been researching water/meth to lower my IAT's.
