LSA Conversion Almost done!
Just needs to be buttoned up and tuned.
2016 2SS 6-Speed Manual... Magnetic Ride Control, Dual Mode Exhaust, Sunroof, Adrenaline Red Interior, Mylink W/Navigation
Added Edelbrock E-Force Supercharger, GM 1LE Sway Bars, BMR Upper/Lower Trailing Arms, BMR Upper Control Arms. BMR Front/Rear Chassis Braces, BMR Tunnel Brace. GM Red knee Pads, GM Black Front Splitter, GM SEMA Concept Grille, GM Dark Taillights, GM Ground Effects package... Savini Di Forza BM-14 Gloss Black Wheels 9's front, 10's rear. |
'It's an experiment'
Looks awesome...
-Don
747 RWHP 794 RWTQ
![]() Drives: Camaro ss 1le Join Date: Jan 2014
looks real nice, love that intercooler, what kind is it?
![]() Drives: 2012 Camaro 2SS/RS Join Date: Dec 2015
looks good
I 2nd the question about the intercooler.
#6 |
It's an AFCO Intercooler.
#7 |
![]() Drives: 2011 Camaro 2SS Join Date: Sep 2015
Did you buy the kit for the conversion or piece it yourself?
#8 |
I bought the ADM kit but the AFCO Unit was separate.
#9 |
Too much is never enough!
Looking good man!
#10 |
"Cam Only"
Is it the AFCO with dual fans?
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq Last edited by Jeff_SS; 01-28-2016 at 09:51 PM. |
#11 |
![]() Drives: 2013 Camaro SS 1LE Join Date: Oct 2014
looks good
#12 |
No fans, just the double pass heat exchanger.
#13 |
Thanks guys!
#14 |
Drives: Anything I want Join Date: Oct 2008
We have the afco and adm as well in stock. With and without fans.
Its a must when you run higher boost |
