Old 02-01-2016, 06:02 PM   #1
DriftinSSRS
DriftinSSRS's Avatar
Drives: 2014 Camaro 1SS RS
Lightbulb Toyo Tires
Is there anyone running the following tires:
Front - Toyo Proxes T1R 255/30ZR21
Rear - Toyo Proxes T1R 285/30ZR21
I plan on mounting them on GM OEM 21" Camaro wheels 8.5" front width, 9.5" rear width. These will then be installed on my 2014 SS/RS.
What is your experience with these tires? Any tires experts have an opinion on the tires?
I know these Toyo's are not the same size as the P Zero's that are recommended but they are close. Any figment issues?
Thanks
2014 Camaro 1SS/RS, MT, Dual Mode exhaust
2015 Camaro 2LS
1970 Camaro......sadly, no longer with me
DriftinSSRS is offline   Reply With Quote
Old 02-02-2016, 08:47 PM   #2
DriftinSSRS
Any Toyo Tire users out there? Comments, remarks, opinions regarding the above post?
2015 Camaro 2LS
Old 02-03-2016, 08:28 AM   #3
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
I ran those on my G35 coupe years ago... for about a day. The sidewalls were so sloppy, I thought I was going to lose control on the highway because it felt like the car was floating back and forth while trying to go straight!?
I don't know if they've improved them since then, but I would not buy them again to find out. 'Hope this helps.
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq
fldrummer is offline   Reply With Quote
Old 02-03-2016, 09:31 AM   #4
rray
rray's Avatar
Drives: 2013 GAZ 2SS/RS
I have been looking for 21's too, but the load rating on the Toyo's is about 400lbs less per tire than the Pzero's. I'm still looking.
Sent from my A0001 using Tapatalk
If you see it, get it, for tomorrow it may be gone!
rray is offline   Reply With Quote
Old 02-03-2016, 04:01 PM   #5
DriftinSSRS
Thanks fldrummer and rray. Both helpful replies. Based on that I may go with Hankooks or (God Forbid $$$$) the P-Zero's.
2015 Camaro 2LS
Old 02-03-2016, 04:54 PM   #6
philthy
philthy's Avatar
Drives: 1971 Monte Carlo/2010 Camaro 2LT
Had my Toyos for a year....absolutely HORRIBLE on wet roads!
2024 Camaro SS convertible
2010 Camaro 2LT
2019 Cadillac CTS
1971 Monte Carlo
philthy is offline   Reply With Quote
