Old 02-02-2016, 04:40 PM   #1
TXMDE
TXMDE's Avatar
Drives: 2014 Camaro SS Rs
Turbo cam
I need a good recommendation on a decent turbo cam. Thanks
TXMDE is offline   Reply With Quote
Old 02-02-2016, 06:15 PM   #2
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
What's your goal? There's some good power to be had with a Brian Tooley Turbo cam. Stage 1 or 2 for nice driveability but some power gain, Stage 3 or 4 for mo' power but gets a little rocky low RPMs. That's all I can speak to. Heard there's plenty of custom grinds around that will do the job. But, a cam really isn't necessary to make the power, unless you're looking for the BIG numbers.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 02-02-2016, 06:20 PM   #3
supergt99
supergt99's Avatar
Drives: 2013 Camaro SS 1LE
whats your goal?
supergt99 is offline   Reply With Quote
Old 02-02-2016, 06:32 PM   #4
TXMDE
TXMDE's Avatar
I just want to hit 700hp mark and get into the 10's. I do want some lope. I currently have the nightfury cam but am going single turbo. Im not sure how well that combo would work.
Old 02-02-2016, 09:19 PM   #5
dreksnot
dreksnot's Avatar
Night Fury matches up nicely with a single turbo. I'd keep the NF.
Old 02-03-2016, 02:38 AM   #6
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
If your dead set on changing your cam, from the NF. Then I would call Brian Tooley up and talk to them about what your goals are, and let them spec you a cam. Or not just Brian Tooley, there are a few other places that can recommend a cam, ADM, and FSP off the top of my head, I am sure would be happy to sell you one of their custom grind cams.
The thing with turbos is, all you really need to do to make more power is turn up the boost, you really don't need a cam at all to do that. Unless you want the chop of a cam. That was what I wanted out of my car.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 02-03-2016, 08:06 AM   #7
Unreal
Drives: 2006 Z06
Depends on the kit, turbo, AR, downpipe. The more restrictive the exhaust side is, the more the overlap will hurt you. The less efficient a turbo setup, the more a cam matters.
Nick
Corvette Z06 -1200ish rwhp
