Old 02-02-2016, 07:03 PM   #1
xXSicSicSicXx
Drives: 14 1LE
What sounds best..
Cam package or save for ECS 1500 kit?
xXSicSicSicXx is offline   Reply With Quote
Old 02-02-2016, 07:07 PM   #2
bct10985
Drives: 2010 2SS LS3, 2013 duramax
No matter which you get first you will soon want the other.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 02-02-2016, 07:14 PM   #3
xXSicSicSicXx
Drives: 14 1LE
Lol I already see that happening.. I just want the car to scare me a bit..
Old 02-02-2016, 08:05 PM   #4
1LESSCamaro
Drives: 07 Sierra Denali, 15 1LE
I'm going with a cam first. When I get tired of that I'll get a set of twins.
1LESSCamaro is offline   Reply With Quote
Old 02-02-2016, 08:12 PM   #5
mdntmank
Drives: ADM TUNED AND BUILT
Do both
Do both at same time regardless.....whats 399 for cam
mdntmank is offline   Reply With Quote
Old 02-02-2016, 08:28 PM   #6
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
If you have the money do both. Otherwise you'll spend more on labor and twice on a tune
camarosspower is offline   Reply With Quote
Old 02-02-2016, 08:51 PM   #7
BrainleSS
Working on my 2nd one!
BrainleSS's Avatar
Drives: Camaro
+1
[SIGPIC][/SIGPIC]
BrainleSS is offline   Reply With Quote
Old 02-02-2016, 10:18 PM   #8
xXSicSicSicXx
Drives: 14 1LE
I wish I could do both.. cam package is way more than 400 if done right.. right now it's one or the other
Old 02-02-2016, 11:04 PM   #9
AGP Turbo
Drives: All things Turbocharged
Save for blower. These cars are too heavy to be fun without FI. Get to the FI as fast as you can.
AGP Turbo is offline   Reply With Quote
Old 02-02-2016, 11:46 PM   #10
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Amen
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 02-03-2016, 02:32 AM   #11
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
I think you should do the blower first.
You do the cam, and you'll wish you did the blower. You do the blower without doing the cam, and you will end up wanting that extra 50 or so hp that you will get from the cam. Speed and power are addictive. If you play your cards right, you can do both at the same time. Then add some meth. Or some nitrious. But hell what do i know, im crazy and cant get enough of either one, speed or power.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
