Old 02-03-2016, 07:15 PM   #1
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
Question Subframe connectors worth it?
Those of you who have subframe connectors, have you noticed any improvement as far as wheel hop is concerned? What about your launch? I'm thinking of going with maybe the Lakewood subframe connectors to suffice for not have subframe bushings. And yes I am aware that subframe bushings is the best upgrade option in terms of eliminating wheel hop, but I don't have a place to install them at my apartment and do not want to spend the install price. Any feedback would be appreciated.
booneSS13 is offline   Reply With Quote
Old 02-03-2016, 08:34 PM   #2
SPCBA
Drives: pleather and Chiclets
No. I use mine as a skid plate on the track tho, best weight I ever added, bouncing off my granatelli brace since 2013
SPCBA is offline   Reply With Quote
Old 02-04-2016, 08:17 AM   #3
booneSS13
booneSS13's Avatar
lol wow that's funny. Not a bad Idea though. What's your power level?
Old 02-04-2016, 06:14 PM   #4
TECHTURTLE
TECHTURTLE's Avatar
Drives: 2016 Camaro 2SS
I noticed a difference when I installed my Hotchkis Brace.
2016 2SS 6-Speed Manual... Magnetic Ride Control, Dual Mode Exhaust, Sunroof, Adrenaline Red Interior, Mylink W/Navigation
Added
Edelbrock E-Force Supercharger, GM 1LE Sway Bars, BMR Upper/Lower Trailing Arms, BMR Upper Control Arms. BMR Front/Rear Chassis Braces, BMR Tunnel Brace. GM Red knee Pads, GM Black Front Splitter, GM SEMA Concept Grille, GM Dark Taillights, GM Ground Effects package... Savini Di Forza BM-14 Gloss Black Wheels 9's front, 10's rear.
TECHTURTLE is offline   Reply With Quote
Old 02-04-2016, 06:38 PM   #5
hammdo
'It's an experiment'
hammdo's Avatar
Ditto..
-Don
747 RWHP 794 RWTQ
Old 02-04-2016, 08:57 PM   #6
booneSS13
booneSS13's Avatar
Would you say it's a worthy substitute for subframe bushings? At least temporarily all I have now is bmr trailing arms and outer trailing arm bushings
Old 02-04-2016, 10:33 PM   #7
Rocco70
THE YETI
Rocco70's Avatar
Drives: 2SS RS
Do your toe rods very easy to do cheap upgrade and it will help a lot.
Rocco70 is offline   Reply With Quote
Old 02-05-2016, 12:01 PM   #8
SPCBA
For me? No. Others report improvements that numbers don't exist for.
Old 02-05-2016, 01:34 PM   #9
BMR Sales
BMR Sales's Avatar
Drives: Race Car
No, do the Cradle Bushings!
Old 02-05-2016, 04:17 PM   #10
hammdo
hammdo's Avatar
No, solids make the biggest difference. The brace limits but does not stop all the movement - speaking only about the Hotchkis. Solids over brace.. And I have both. Did the brace before I could get the solids mostly it was easy, reasonably priced, and effective enough to make a difference...
-Don
747 RWHP 794 RWTQ
Old 02-05-2016, 08:33 PM   #11
booneSS13
booneSS13's Avatar
those are on the list too. I definitely want to get those done
Old 02-05-2016, 08:35 PM   #12
booneSS13
booneSS13's Avatar
As far as the bushings go has anyone come up with an easier way to get the stock one's out and the new ones in? If I do decide to do it it will be on the ground in the back of my apartment. Will that be a job I can do without a garage?
Old 02-05-2016, 09:10 PM   #13
hammdo
hammdo's Avatar
Not really, they are work..
On the Hotchkis...
Here is a vid showing the difference... Does not stop it, but does limit it.
I found the same results. Solids eliminated it totally...
-Don
747 RWHP 794 RWTQ
Old 02-06-2016, 12:54 PM   #14
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
Look on the how to section. Mar10 is doing a how to right now. That's the way I done mine and its not that bad. I'm going to do this again on another ss
camarosspower is offline   Reply With Quote
1/4 mile, drag racing, launching, subframe bushings, subframe connectors chassis
