Old 02-05-2016, 05:06 PM   #1
DsCamaro1
DsCamaro1's Avatar
Drives: 2011 SIM 2SS RS L99
WHIPPLE ON STOCK ENGINE??????
Can I install the 2.9l whipple on stock engine with stock headers?? I would have the Cat's deleted and use the stock exhaust. If I keep it on low boost will I be ok for a while or do I have to upgrade the drive shaft and torque converter right away? And will the stock headers hold up to the boost??
DsCamaro1 is offline   Reply With Quote
Old 02-05-2016, 05:10 PM   #2
13FastBlkSS
Drives: 2013 Camaro 2SS/RS M6
I don't have a whipple but I have a Maggie TVS2300.. my engine is stock with stock headers and stock exhaust, my engine is holding up great so far.. I'm running at 8#'s of boost. It's all about the tune, if you get your car tuned by a reputable person who knows what they are doing.. your car will last a long time.
2013 Black / Black Camaro 2SS/RS M6 w/Magnuson TVS2300, ZL1 Fuelpump / ADM FPCM, NPP Exhaust, Cold Air Inductions CAI w/ Scoop, Elite Engineering Catch Can, VMAX Ported TB, OEM 1LE Front Splitter, AAC Ghosted Side Markers, Dropped on BMR Split Drop Springs
Build#24869
13FastBlkSS is offline   Reply With Quote
Old 02-05-2016, 05:18 PM   #3
DsCamaro1
DsCamaro1's Avatar
What's did yours dyno at??? Mine is an automatic so I know I'll be less.
Old 02-05-2016, 05:22 PM   #4
13FastBlkSS
535RWHP / 472 RWTQ @8 PSI w/stock pulley
Build#24869
Old 02-05-2016, 05:27 PM   #5
DsCamaro1
DsCamaro1's Avatar
Originally Posted by 13FastBlkSS View Post
535RWHP / 472 RWTQ pulley
That's not bad for stock. I'm still torn between whipple or a TT system. I still haven't decided.
Old 02-05-2016, 05:28 PM   #6
Brad7294
Drives: 2010 2SS/RS LS3
You sure can! I would get it tuned By a good tuner. I used race proven motorsports in DE. I did put a blower cam in it also. They got we down at 747 rwhp and 627 rwtq. with 11 psi boost. That's about all you want to go on a stock block before it goes boom.
Brad7294 is offline   Reply With Quote
Old 02-05-2016, 05:31 PM   #7
Strong66
Drives: 2013 SS whipple
My car is stock other than the whipple 500 HP 493 TQ im on the whipple tune the car runs great but a custom tune would pick up some power
Strong66 is offline   Reply With Quote
Old 02-05-2016, 06:34 PM   #8
DsCamaro1
DsCamaro1's Avatar
What are some problems you all have encountered with a supercharger?
Old 02-05-2016, 06:43 PM   #9
Strong66
Only problem ive had is no traction
Old 02-05-2016, 06:53 PM   #10
DsCamaro1
DsCamaro1's Avatar
That can be fixed with smaller rims and some Mickeys. Actually what is the smallest rim you can put on a stock SS. I heard it was 18inch but I'm not sure.
Old 02-05-2016, 07:19 PM   #11
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
Pretty sure you can get a 16 inch on there but a lot of people run 17's. You will be happy with both just have to decide which one.
MODS:
Old 02-05-2016, 07:25 PM   #12
DsCamaro1
DsCamaro1's Avatar
[QUOTE=10aSSee D;8885532]Pretty sure you can get a 16 inch on thefigure lot of people run traction u will be happy with both just have to decide which one.[/Qill E]
Do you have any recommendations as to where to buy these rims. i figure I'll need alot more traction to get moving quickly. Either way if I get TT or whipple I'll need better tires.
Old 02-05-2016, 07:47 PM   #13
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Do yourself a huge favor and get an agp kit. You will be much happier in the long run
ttshovel is offline   Reply With Quote
Old 02-05-2016, 08:32 PM   #14
10aSSee D
10aSSee D's Avatar
What kind of rims are you looking for?
MODS:
