Old 02-05-2016, 10:57 PM   #1
4510
Drives: 2013 2SS/RS Rally Yellow
ZL-1 Rear Diff Cooler Setup
Doing the ZL-1 Rear Diff/Axle upgrade on a 2013 Camaro SS, M6. Does the SS manual have the necessary fittings on the transmission to support the ZL-1 Rear Diff cooler?
If so, is there a ready source for the cooler lines?
Thanks in advance!
2013 Camaro 2SS/RS-6spd- Rally Yellow / AGP Twin Turbo
2015 Challenger Hellcat-6spd- Sublime
I think I see a trend here....
4510 is offline   Reply With Quote
Old 02-06-2016, 12:31 AM   #2
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
I presume the T6060 on the SS is the same as the ZL1. AFAIK, there isn't a 'kit' for the cooler setup. I found an exploded diagram with all the parts, added the lines, fittings, hangers, etc. to my cart and it tallied over $450 from a discount parts place. So.... might be easier to find a ZL1 that someone is parting out.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 03-18-2016, 12:16 PM   #3
4510
Do you happen to have the list of parts and the discount website? I'd like to consider that as an option.
Old 03-18-2016, 12:35 PM   #4
dreksnot
dreksnot's Avatar
http://www.tonkinonlineparts.com/showAssembly.aspx?ukey_product=6404441&ukey_assemb ly=1283103&ukey_make=1086&ukey_model=15720&ukey_dr iveline=0&ukey_trimlevel=26615&modelYear=0
Have at it!
Old 03-18-2016, 12:48 PM   #5
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
The ZL1 manual is TR6060 with the MG9 option
http://www.chevrolet.com/performance...g9-tr6060.html
Old 03-18-2016, 12:55 PM   #6
4510
Thanks both... I am just trying to source the lines and fittings. I believe that the existing SS transmission has the appropriate ports to connect the lines to.
Old 03-03-2017, 06:20 PM   #7
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
Hi 4510......did you get all your parts and did
it hook up OK? If so from where?
I am doing the same thing!
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned|
God is too good! I don't deserve it, but I sure will accept it!!!
ZX1truth is offline   Reply With Quote
Old 03-03-2017, 07:51 PM   #8
4510
No I didn't proceed. My exhaust is VERY tight in that area and wasn't sure that I could run the lines.
Old 03-06-2017, 08:15 PM   #9
Mnhdrider
Drives: 15 black 2SSRS1LE
This is what I installed
KEEP YOUR COOL
Z/28 REAR DIFFERENTIAL MODULE COOLER KIT
P/N 23216684 / MSRP: $750.00†
The Camaro Z/28 is equipped with an RDM cooling system that circulates cooled transmission fluid through a heat exchanger integrated into the RDM cover. This innovative system reduces oil temperature by more than 100°F, helping the differential maintain cool, stable performance throughout the most aggressive track driving sessions. The Z/28 system has greater heat-rejection capability than competitors’ air-cooled RDMs, helping to prevent differential component damage from high-temperature oil degradation. The integral heat exchanger design also eliminates the weight, noise, and complexity of a dedicated external pump and its associated hardware, seen in many aftermarket systems. This Z/28 based RDM cooling kit can be applied to any 2010 and later Camaro SS with a manual transmission.
Mnhdrider is offline   Reply With Quote
Old 03-06-2017, 08:29 PM   #10
4510
KEEP YOUR COOL
Everything I see on that part number references a Camaro SS rear differential. In my case I installed the ZL1 Diff, Axles and Driveshaft. I don't think this cover will fit the ZL1 Diff.
Old 03-08-2017, 01:25 AM   #11
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
KEEP YOUR COOL
Did you install this on a ZL1 diff???
Old 03-08-2017, 05:29 AM   #12
dreksnot
dreksnot's Avatar
Z/28 cooler will not fit on ZL1 diff
Old 03-08-2017, 11:35 AM   #13
ticowarbird
BOHIC
ticowarbird's Avatar
Drives: 2010 Camaro SS "Enola"
I got my cooler lines from hawks but haven't installed them yet. Posted several times looking for the same thing you are. Will probably install it in May when I'm home for a couple weeks.
What else can I do to my Camaro?
ticowarbird is offline   Reply With Quote
Old 03-09-2017, 09:48 PM   #14
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
A lot of the parts DrekSnot posted on his parts list are not available from GM any more!!! DANG!!! Might have to look for a stand alone auxiliary cooler for it now! Just found this Cusco system........it may work?!?!?!? https://www.rallysportdirect.com/par...ial-cooler-kit
