Old 02-06-2016, 10:42 AM   #1
cbarile
Drives: zl1
what would cause this?
I have 2012 automatic 20k miles with ported blower, headers with hiflo cats,2.38 pulley,blower spacer,cai,tune, all work done by formato. I can't get car to him for 2 weeks as he's busy so I thought I'd try here. My check engine light has come on 5-6 times in past month codes are P0171-P0174 lean bank codes. I noticed the engine light after fueling the car on the last few occasions so this morning with a 1/2 tank of fuel and no check engine light on I fueled up at shell gas station with 93 as i always do. I put 7 gallons in wich did not fill it all the way up but when I started the car I watched the engine light come on. What could be causing lean codes by simply putting gas in car and starting it? Anyone else have this issue? I appreciate any input.
cbarile is offline   Reply With Quote
Old 02-06-2016, 11:41 AM   #2
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Fuel pressure?
Check your fuel pump pressure....just guessing here...
Mods:
Old 02-06-2016, 11:53 AM   #3
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
http://www.obd-codes.com/p0171
Old 02-06-2016, 02:30 PM   #4
99frc
Drives: 2015 Camaro ZL1
Probably bad O2 sensor
2015 ZL1 #377
99frc is offline   Reply With Quote
Old 02-07-2016, 01:19 PM   #5
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Not likely if it's affecting both banks. P0171 and P0174
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 02-07-2016, 01:36 PM   #6
derklug1
derklug1's Avatar
Drives: 2016 GT350
Only thing I could think of is a vent solenoid sticking and making a vacuum leak when the purge solenoid engages, but that should also be giving you evap codes. Since it takes three times to set the evap, maybe the purge vacuum eventually closes the vent solenoid. If you have a scanner that allows you to monitor, fill the tank and then see how long it takes for the fuel tank pressure to go negative.
"Life is hard, it's harder if you're stupid" John Wayne
derklug1 is offline   Reply With Quote
Old 02-07-2016, 04:09 PM   #7
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
fueling in the tune is likely to be off...the maf curve needs adjusting
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 02-07-2016, 04:12 PM   #8
99frc
Ah yes, you're right. Missed that.
2015 ZL1 #377
Old 02-07-2016, 05:44 PM   #9
cbarile
Drives: zl1
I forgot to mention this, formato tuned the Car one year ago and the engine light thing just started happening a little over a month ago. Yesterday when the light came on it went off few hours later by itself. I usually go to advance have code read and cleared.
