![]() ![]() Drives: 2014 camaro ls Join Date: Jan 2015
throttle controller
can you you guys please help me out real quick
![]() ![]() I'm trying to install the vitnesse throttle controller but I CAN NOT FOR THE LIFE OF ME get through step number one!! - Unplug the Harness on top of your Gas Pedal (First you will need to push up the securing gray pin, after that while squeezing in the middle of the harness, pull the harness upward by holding the plastic connection, not from the wires ! anyone have like a step by step pictures?? It's so frustrating ![]() |
Vet. USMC Machine Gunner
Drives: 2010 2SS Black with red stripes Join Date: Sep 2013
Have you taken the pin out yet
![]() ![]() ![]() ![]() Drives: Iron Lung, Jimmy Join Date: Jun 2009
Your car is trying to tell you something.
Kyrac
Drives: 2018 2SS A8 Join Date: Feb 2015
I must have gotten lucky on my install because I just had to use a small screwdriver on the clip and the plug came right out... Then it was just a matter of plugging in the new harness, what ever you do, don't force it!!! Just take your time and keep trying to work it loose in front and back, then it should just pop right out, good luck!!!
Drives: car Join Date: Apr 2015
#6 |
![]() ![]() Drives: 2010 Camaro SS Victory Red Join Date: Apr 2015
Don't force anything, and don't break it it will come off, mine was a PITA, but it knew better. You break that connector you'll be walking....
Speed Engineering Headers w/ Texas Speed HFC's ~ Flowmaster 2 1/2" cat back w/Flowmaster Super 10's ~ Cold Air Inductions Intake w/ Scoop and WW relocate ~ VMAX CNC Spiral PTB ~ Cross Drilled and Slotted Rotors w/Hawk pads ~ ZL1 Spoiler ~ SCTX4 RDP Tuned
#7 |
I finally got it a little after I posted this! haha oh man it was so simple!! I should slap myself! haha
but anyway... the camaro feels like a totally different car when I have it in sp9!! |
#8 |
Snappy is the word you are looking for
#9 |
Got mine!
Drives: 2021 LT1 RS - Orange Crush Join Date: Mar 2011
Yup mine was a bee-otch to disconnect too.
Camaro lover since 1984 when I got my first car a 1978 Camaro LT with a 2 barrel carb on 305 V8... yes I put in a 350 with a 4 barrel.
#10 |
![]() Drives: 2012 1LT SIM Camaro Join Date: Sep 2012
#11 |
Banned
Drives: 2015 Camaro 1LS M6 Join Date: Jan 2016
How much faster does this throttle controller make the car? I did a search and it seems it reduces the 0-60 times by a few tenths on the V6 models. Is this true?
#12 |
![]() Drives: 2013 Camaro ZL1 Join Date: Dec 2015
I would think its only reducing the time due to wheel spin. With the VTC you're not gaining any horse power you're just getting more throttle sooner. Example: if the factory setting is giving you 10% at 1\4 throttle the VTC depending on what setting you use will give you 30% at 1\4 throttle.
