Old 02-12-2016, 09:30 PM   #1
damian559
damian559's Avatar
Drives: 2015 1SS, 1LE, Recaro, NPP
Max nitrous to spray
I'm currently spraying a 150 shot pulling the fuel from the rails. I just bought a dedicated fuel cell, and was wondering if I could up the shot to a 175 or 200? I know the fuel will be able to supply the necessary amount, I'm just curious about the motor.
If I keep it at a 150 shot, will I gain any horsepower from using C16 in the fuel cell?
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor)
647 RWHP 723 RWTQ (150 Shot)
12.1 @ 117 (Motor)
11.7 @ 129 (Nitrous)
Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports
Youtube Channel:
Click Here
damian559 is offline   Reply With Quote
Old 02-13-2016, 08:27 PM   #2
damian559
damian559's Avatar
Bump. Anyone?
12.1 @ 117 (Motor)
Youtube Channel:
Click Here
Old 02-13-2016, 10:41 PM   #3
Aries240SS
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX
The motor is not the weak point for nitrous. The tune is.
Detonation is the killer of all nitrous motors.
Stock ls3 motors can take 300+ HP of nitrous. It's just about pulling the right amount of timing with the right fuel and plugs to keep it safe.
2011 Camaro 1SS
Whipple Supercharged 1150/1100 @ 24psi - Removed blower and went Turbo
Huron Speed T6 1135/1070 @ 20psi so far. 15 more PSI loading...
Aries240SS is offline   Reply With Quote
Old 02-14-2016, 09:32 PM   #4
Joseph1LE
Drives: 2015 Camaro SS 1LE, 2001 Camaro SS
300 max on stock bottom end and tune has to be absolute perfection. I think 200-250 is the sweet spot if you're going for big power on spray with a stock bottom end. Withe C16 in the fuel cell you could probably run a little more timing and pick up some power on the 150 hit.
2017 GMC Canyon All Terrain- daily driver/dirt bike hauler
2015 Camaro SS 1LE- sold
2001 Camaro SS SOM M6- sold
1999 Firebird Formula A4- sold
Joseph1LE is offline   Reply With Quote
Old 02-14-2016, 11:34 PM   #5
damian559
damian559's Avatar
So upping it to a 200 shot should be fine?
12.1 @ 117 (Motor)
Youtube Channel:
Click Here
Old 02-15-2016, 06:45 AM   #6
Joseph1LE
As long as you are using a dedicated system like you have to ensure good fueling, and your tune is on point then yes a 200 is no problem at all. Make sure you pull a little more timing and monitor everything on the dyno and tuner can make adjustments as needed.
On a 200 shot 1 bottle isn't going to last long at all just a heads up. If you're out racing make sure you have a 2nd bottle to swap it out with after 3 passes or so. Or just run two bottles at once and that will be much more consistent.
Old 02-15-2016, 04:20 PM   #7
damian559
damian559's Avatar
I might just keep it at 150 for now, and get used to that. I still haven't dig raced it on bottle yet. How much should I pick up from switching over to the fuel cell with c16?
I wish I wouldve went with the dual bracket, I might sell mine and buy it. How do you hook up it so you can run both bottle, a 'Y' fitting?
12.1 @ 117 (Motor)
Youtube Channel:
Click Here
Old 02-15-2016, 05:49 PM   #8
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Yes y both bottles to your line you ran. You're not going to pick up much on the same tune running the standalone. The c16 in the tank will allow higher timing to be run and that's where more power is made with the tune.
Depending how much your stock pump was dropping pressure with the standalone it might be a little rich up top now. Do you have a wideband to monitor afr and any way to watch if the motor knocks? If not I'd get the tune touched up or at least looked at especially if going to a bigger jet
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 02-15-2016, 07:59 PM   #9
damian559
damian559's Avatar
So both bottles are open at the same time? Do I have to get 2 bottle pressure gauges or am I fine with just one? Sorry if these are stupid questions.
Yes I have a wideband. Once the fuel cell gets installed my shop was going to put it on the dyno anyways to double check all the AFR. Currently I'm on a 150 shot with 6 degrees pulled, I'm wondering if itd be better to only pull 4 or 5 degrees and run a 150 still or put the 175 or 200 jets in and pull around 7 degrees.
12.1 @ 117 (Motor)
Youtube Channel:
Click Here
Old 02-15-2016, 08:07 PM   #10
fif_gen_powa
Each bottle needs a gauge on it the cheap small ones.
Put it on the dyno and dial in a 200 shot. You can always back down to a 150 shot or whatever later
8.3@164
