Old 02-13-2016, 12:00 PM   #1
CyberGreyConvertible
Dunder Mifflin Inc.
CyberGreyConvertible's Avatar
Drives: 2012 2SS/RS Convertible
Need clarification on gear swap!
Hey, guys. I'm looking to swap out my 3.27's for either 3.73's or 3.91's, but I really can't find a definitive answer of which ratio to choose.
My car:
• 2012 SS, Auto
• Only bolt ons (LT headers) + tune
• NOT planning on getting it cammed
So, which do you think I should go with? I've done searching around the forums, but I still can't decide.. Some people say that 3.91's are best for cammed engines, for example.
All in all; I can't decide which gear ratio to choose! I appreciate all input here,
Thanks!
CyberGreyConvertible is offline   Reply With Quote
Old 02-13-2016, 12:07 PM   #2
blakjak55
drinks virgil's
blakjak55's Avatar
Drives: 2010 2SS M6
Rule of thumb seems to be 3:91's for N/A and 3:73's for FI.
Mine's an M6 but even if I went FI I'd keep my 3:91's and put the money in suspension for grip.
2010 2SS/RS M6 - CAI Intake - Borla Stinger - VTC - 3.91's
Eibach Sways - LG ZR28's - BMR Springs - 285/35 Squared
blakjak55 is offline   Reply With Quote
Old 02-13-2016, 03:03 PM   #3
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
My car:
• 2012 SS, Auto
Thanks!
Im getting 391s in the spring....my tuner recommends them. They have done alot of those with great results. So i would say 391s.
rontammy0 is offline   Reply With Quote
Old 02-13-2016, 05:51 PM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
My car:
• 2012 SS, Auto
Thanks!
There isn't necessarily a right or wrong answer. If you don't plan on doing more than bolt on mods then 3.91s will give you the most bang for your buck. 1st gear is really short though.
By upgrading the factory 3.27s in the stock A6 equipped Camaro SS to the 3.73s you will realize an equivalent torque gain of approximately 15% or 62 lb.-ft. of torque and cruise at 2050 RPM at 70 MPH. By upgrading to the 3.91s you will realize an equivalent torque gain of approximately 20% or 82 lb.-ft. of torque and cruise at 2150 RPM at 70 MPH.
Old 02-13-2016, 05:58 PM   #5
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
he has a auto 3.73 is recommended. 3.91 for stick.
JCunningham is offline   Reply With Quote
Old 02-13-2016, 06:52 PM   #6
mfarhan_amin
mfarhan_amin's Avatar
Drives: Camaro 2SS 2013
I have 3.91 with Kooks LT, CAI and Tune. I am running VTC on SP6. Just Amazing Torque and Throttle Response.
But Traction is a big problem specially launching from 0 in 1st Gear. 2nd Gear do Good.
Launching from 20MPH is Awesome. Seat of the Pants feeling is Simply WOW.
Camaro 2013 2SS/RS L99 VICTORY RED
VMAX PORTED THROTTLE BODY, ROTO-FAB CAI, FLOWMASTER OUTLAW AXLE-BACK WITH J-PIPES. VITESSE THROTTLE CONTROLLER. 1LE 3.91 GEARS. KOOKS 1 7/8 LTs, CAT DELETE, GPI SS2 VVT CAM, ATI 10%
UDP, MELLING HIGH VOLUME HIGH PERFORMANCE OIL PUMP
mfarhan_amin is offline   Reply With Quote
Old 02-13-2016, 07:20 PM   #7
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
3:91 for a boosted 4l80 car.
Trob85 is offline   Reply With Quote
Old 02-13-2016, 08:36 PM   #8
christianchevell
old school chevy rodder
christianchevell's Avatar
The deal is the production of the 1le made the 3:91s cheaper ..... so do what you want the gears are not much more drastic from a 3:73 .
Old 02-13-2016, 08:40 PM   #9
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
The 3.73 are to automatics what the 3.91s are to the manual cars.
Like stated above it makes 1st gear really short and don't think there is a speedo recal for automatics for either gear set from GM.
Orange Krush II
Old 02-13-2016, 10:19 PM   #10
OHIOSS
Russ
Drives: Yukon Denali, Charger, CamaroSS
Send a message via AIM to OHIOSS
I have an M6 in my SS and I changed to a 3.91 rear end. It made a huge difference in the performance, one of the best mods I've ever done.
OHIOSS is offline   Reply With Quote
Old 02-13-2016, 10:35 PM   #11
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
3.91s
RIGHT!!!!!
Get a Z/28 intake and see how you like them then it's huge!!!
Orange Krush II
Old 02-14-2016, 06:48 PM   #12
jergarr
jergarr's Avatar
Drives: 11' RJT 2SS/RS L99
My car:
• 2012 SS, Auto
Thanks!
I have the 3.91's in my L99 and I wish I had done them sooner. My only real complaint is the higher rpm's on the highway can get annyoung at times but that's the trade off. I ran a 12.4 1/4 mile with 1.85 60' this past fall. At the moment I do plan on going with an aftermarket cam in the next year but the gears by themselves are a good mod.
GPI VVT3 Cam
Circle D 3800 Single Disc Stall
1LE 3.91s
Stainless Power Headers w/cats
Fluidampr 25% UDP
Cold Air Inductions Intake
Bo White Ported Throttle Body
ADM Trans Cooler
Some BMR Goodies
jergarr is offline   Reply With Quote
Old 02-14-2016, 07:04 PM   #13
jergarr
jergarr's Avatar
I was worried about the short first gear but it's definitely not undriveable by any means. My installer was able to recalibrate the speedo as well.
GPI VVT3 Cam
1LE 3.91s
Fluidampr 25% UDP
ADM Trans Cooler
Some BMR Goodies
Old 02-14-2016, 07:47 PM   #14
rontammy0
Did you track it before your 12.4 et. I'm wondering how the 391s will help my et and 60ft. Thanks
