Old 02-14-2016, 06:42 AM   #1
Bubble85
Drives: 2012 SS
4th gear vs 5th gear on dyno
The shop that tuned my car had to do the pull in 5th because 4th had too much torque for the dyno I was told. What kind of difference does that make in numbers?
Bubble85 is offline   Reply With Quote
Old 02-14-2016, 07:46 AM   #2
MarioSS
MarioSS's Avatar
Drives: 2010 Camaro SS (RS LS3)
I think it's always done on 4th gear pulls.
Think 5th gear pulls will lead to lower numbers. Hope someone can confirm this
Sent from my Nexus 6P using Tapatalk
MarioSS is offline   Reply With Quote
Old 02-14-2016, 08:44 AM   #3
Mise
Drives: 2014 soon to be Copo
You need to do your dyno pulls in what ever gear is a 1-1 Ratio in most Standard transmissin cars it's 4 and most autos it's 3rd
Mise is offline   Reply With Quote
Old 02-14-2016, 12:31 PM   #4
Indyblue98
2012 RS 2ss
Drives: 2018 ZL1 2012 2SS WhippleCharged
1st Gear Ratio
4.027
2nd Gear Ratio
2.364
3rd Gear Ratio
1.532
4th Gear Ratio
1.152
5th Gear Ratio
0.852
6th Gear Ratio
0.667
Reverse
3.064
My Tuner used 4th
2018 ZL1 A10 and 2012 2SS RS Whipple-Corsa-RotoFab-ZL1 Diff 3.73 Pfadt ZL Stage 3 Suspension+
Indyblue98 is offline   Reply With Quote
Old 02-14-2016, 12:35 PM   #5
Unreal
Drives: 2006 Z06
Typically numbers will be a bit lower.
Nick
Corvette Z06 -1200ish rwhp
Old 02-14-2016, 04:16 PM   #6
Bubble85
Drives: 2012 SS
Thanks guys. Any one smart enough how to calculate the difference?
Old 02-14-2016, 04:37 PM   #7
blakjak55
drinks virgil's
blakjak55's Avatar
Drives: 2010 2SS M6
Take the results and multiply by .852 for a ballpark.
2010 2SS/RS M6 - CAI Intake - Borla Stinger - VTC - 3.91's
Eibach Sways - LG ZR28's - BMR Springs - 285/35 Squared
blakjak55 is offline   Reply With Quote
Old 02-14-2016, 05:12 PM   #8
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
My tuner always tries to use the gear closest to 1:1 for dyno pulls. So 4th gear for mine.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 02-14-2016, 05:18 PM   #9
SoChrisB
SoChrisB's Avatar
Drives: 2012 Camaro 2SS/RS
That's interesting to know. My car was dyno'd in 5th gear. Makes me feel better about my number after recalculating based on the gear ratios.
SoChrisB is offline   Reply With Quote
Old 02-14-2016, 05:24 PM   #10
Bubble85
Drives: 2012 SS
770x.852=656
That can't be right
Old 02-14-2016, 05:50 PM   #11
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
so if a 3.91 swap 5th would be a .96276 ratio at 13% increase I am thinking
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
Bretts is offline   Reply With Quote
Old 02-14-2016, 05:51 PM   #12
Unreal
Drives: 2006 Z06
Rear end gear doesn't effect transmission ratios.
Nick
Old 02-14-2016, 05:58 PM   #13
blakjak55
drinks virgil's
blakjak55's Avatar
Drives: 2010 2SS M6
Originally Posted by Bubble85 View Post
770x.852=656
That can't be right
No, I know. I was being sarcastic. My apologies....
Although thinking about it, what all mods do you have done to the car?
Old 02-14-2016, 07:03 PM   #14
Bubble85
Drives: 2012 SS
Agp #12.5 cam meth
