Old 02-15-2016, 02:10 AM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Question Stand alone fuel question
So what fuel system should I get? Nitrous outlet or NX? What's the pros and cons between the two.
Also what fuel should I use when spraying? Methanol or C16?
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 02-15-2016, 01:35 PM   #2
damian559
damian559's Avatar
Drives: 2015 1SS, 1LE, Recaro, NPP
I went with Nitrous Outlet because I got a great deal on it, both of them are pretty much the same.
And I'm going with c16. You can't put methanol in a stand alone for nitrous.
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor)
647 RWHP 723 RWTQ (150 Shot)
12.1 @ 117 (Motor)
11.7 @ 129 (Nitrous)
Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports
Youtube Channel:
Click Here
damian559 is offline   Reply With Quote
Old 02-16-2016, 05:03 AM   #3
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
That is false, you absolutely can put methanol in the standalone tank. The selenoids need to have the stainless steel plungers to use it though.
The reason why you don't see a lot of people using it is because it's high maintenance and it's harder to read the plugs. You can just leave it sit in the tank as it will draw moisture.
Go with the c16, it's a lot less of a hassle and easier to tune.
ttshovel is offline   Reply With Quote
Old 02-17-2016, 08:34 PM   #4
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
You also have to pull the foam out of the cell as methanol will break it down.
NX tech said they see no reason methanol can't be used with the solenoids I have.
Old 02-17-2016, 09:43 PM   #5
damian559
damian559's Avatar
I stand corrected.
12.1 @ 117 (Motor)
Youtube Channel:
Click Here
