Old 02-15-2016, 08:14 PM   #1
ccb1975
ccb1975's Avatar
Drives: 2010 WHITE SS
Alpine ine-s920hd no sound
Only sound that I can get out of this is my Nav. other than that nothing.
any thing I can check to see what the problem is? Thanks.
ccb1975 is offline   Reply With Quote
Old 02-15-2016, 10:37 PM   #2
BigRed82
Drives: 2015 2LT RS Camaro
Checked the fuses?
BigRed82 is offline   Reply With Quote
Old 02-17-2016, 11:17 PM   #3
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
can the radio be factory reset? firmware update? maybe the radio just died out?
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 02-17-2016, 11:25 PM   #4
ccb1975
ccb1975's Avatar
Thing is I can hear navigation lady coming thru the speakers like normal. My back up camera still works.
I didn't see any firmware update on Web site.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Old 02-18-2016, 07:04 PM   #5
jeffa
Drives: 2014 2LT/RS Ashen Gray Metallic
What head unit do you have? The factory radio in 2010 did not have navigation.
If it is an aftermarket head unit, maybe something changed the audio settings.
jeffa is offline   Reply With Quote
Old 02-18-2016, 07:07 PM   #6
jeffa
Sorry, was not paying attention.
I had an Alpine 920, but never had the issue you do. Check to make sure that you did not change a setting in the unit that would cause you to loose all audio except the nav voice.
Old 02-18-2016, 10:13 PM   #7
ccb1975
ccb1975's Avatar
just did a factory reset. WORKS!!!
Old 02-18-2016, 10:19 PM   #8
Scotty D2014
Drives: 2014 SS1-1le Crystal red metallic
Alpine's are not the most user friendly head units !! When it come to settings..
Scotty D2014 is offline   Reply With Quote
