Old 02-17-2016, 05:27 PM   #1
SantosNL
Drives: 2012 Camaro 2SS
Whipple or Ecs or Hellion
I'm struggling to pull the trigger on either kit, I'm looking for the best way to have a fast weekend car. I love going to the track and I want to be able to run mid to high 9's 1/4. I want to push my stock bottom end to its limit then switch over to a 427 lsx if ever needed. Right now I just have a cammed l99 to ls3 with a night fury cam and ported heads. I just got a 6l90 trans Ans I'm running 3.73 gears, I don't mind switching gears again if needs be. I just want the best all around set up. I'm also on e85 with fore triple pumps and ID 1700 and I'm also going with bmr drag suspension and coilovers
SantosNL is offline   Reply With Quote
Old 02-17-2016, 05:31 PM   #2
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
Hmmmm. You're going to get a lot of biased answers which, of course, you set yourself up for.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 02-17-2016, 05:41 PM   #3
SantosNL
I had a rear mount turbo set up and I went high 10'a but the lag was so terrible and I haven't seen or even heard of a person on here that has gone 9's turbo
I just want fact and proof
Old 02-17-2016, 05:48 PM   #4
SoChrisB
SoChrisB's Avatar
Drives: 2012 Camaro 2SS/RS
I have a SLP blower. If I could do it over again I would have done Hellion because of its potential.
SoChrisB is offline   Reply With Quote
Old 02-17-2016, 05:52 PM   #5
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Blower cars and turbo cars, both get into the 9's. Seems as though more SC cars are there, but then again, there are a lot more SC cars here on C5. What kind of power are you looking to make?
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 02-17-2016, 05:53 PM   #6
1KillerSS
1KillerSS's Avatar
Unreal will most likely post some for ya, they are out there.
Build thread
Old 02-17-2016, 05:54 PM   #7
SantosNL
Whatever I need to make it in the 9's I was making 770/746
Old 02-17-2016, 06:04 PM   #8
1KillerSS
1KillerSS's Avatar
Running 9's on a stock bottom end is no problem. Why have you limited yourself to just one turbo manufacturer?
I was asking about what kind of power your wanting to make now, not in the past, for a simple reason. If your wanting to keep pushing your car, once you build your stock bottom end, and transmission, then in the long run turbos will be cheaper for big power.
I think its obvious that a SC'd car will get you there without question, and its also no secret that there are not many turbo cars doing it, a big part of that is not because they cant, its because there are just not as many turbo owners out there.
Take a step away from the C5 forum and search the internet, you will find plenty of 9 second turbo cars.
Build thread
Old 02-17-2016, 07:47 PM   #9
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
OP your making 770 RWHP now??
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 02-17-2016, 07:49 PM   #10
SingleT
Drives: 2015 2SS
Agp.
SingleT is offline   Reply With Quote
Old 02-17-2016, 09:33 PM   #11
SantosNL
It was the last dyno I got on when I was in Texas idk how accurate it was but I don't want to go by numbers rather then track times now
Old 02-17-2016, 09:34 PM   #12
SantosNL
Originally Posted by SingleT View Post
Agp.
I really don't want to deal with anything under the car now
Old 02-17-2016, 09:48 PM   #13
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
suspension, and aftermarket stall converter is what I would look at first all the power in the world is no good if you can't efficiently get it to the ground, after that both options should get you to your goal
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 02-18-2016, 08:25 AM   #14
SingleT
Drives: 2015 2SS
What suspension would you suggest?
