Old 02-20-2016, 06:05 PM   #1
B_Rian
B_Rian's Avatar
Drives: 2014 2SS
Anti-Theft Code??
Hey guys, so I'm going to be installing K&N air intake and the instructions advises to disconnect the negative batter cable. It says this will erase memory settings and sometimes radios will require an anti-theft code when the battery is reconnected. Has anyone experienced this? If so, where can I find the anti-theft code; and exactly what settings will be erased when disconnecting the battery?
B_Rian is offline   Reply With Quote
Old 02-20-2016, 06:13 PM   #2
Welker2
Ret AF, cancer survivor
Welker2's Avatar
I have disconnected my battery a few times to install things; never erased or reset my MyLink system or asked for a code.
Old 02-20-2016, 06:15 PM   #3
JD555
JD555's Avatar
Drives: 2014 2SS RS, 6 sp man
I left my bat connected when I did mine.
JD555 is offline   Reply With Quote
Old 02-20-2016, 10:29 PM   #4
trodecke
trodecke's Avatar
Drives: 2014 2SS/RS CRT
I had my battery disconnected for around 4 hours one night and nothing happened except the buttons/lights in my mirror started working again.
Lifetime Camaro guy. 1979 Z28, 1987 LT, 2012 2LS, 2014 2SS/RS
--CAI Cold Air Intake
--Solo HFC
trodecke is offline   Reply With Quote
Old 02-20-2016, 10:38 PM   #5
Jylee
Drives: 2012 2LT
I don't think you need to disconnect your battery to swap out a air filter housing.
Jylee is offline   Reply With Quote
Old 02-20-2016, 11:35 PM   #6
B_Rian
B_Rian's Avatar
Drives: 2014 2SS
thanks for the replies. I just completed the upgrade a couple of hours ago. I left the battery connected and there were no issues
