Old 09-24-2009, 09:25 AM   #1
Pitttbulll
Pitttbulll
Pitttbulll's Avatar
Drives: 2010 Victory Red 2/SS
Cam Advice
Hello.
I was wondering if anyone could give me some recommendations for a cam?
I already have the ARH system and Loudmouth 2's installed.
I'm getting a Procharger installed in the next few weeks.
My next step after that would be a cam swap.
I would like to get a cam that keeps the VVT.
If anyone knows what cam would best compliment my setup, please let me know.
Also, what other components would I need to change also?
Thanks.
Pitttbulll is offline   Reply With Quote
Old 09-24-2009, 09:31 AM   #2
jpsuperman81
Yep I'm back!
jpsuperman81's Avatar
Drives: 2017 Krypton Green 1SS 1LE
You should do a cam at same time as procharger and a tune right afterwards. As for reccomendations I would talk to whoever does your work locally, tell them what your looking for out of the car. People could spit cam numbers at me all day long and I don't know what they mean and i am too impatient to study but i talked back and forth with the place doing mine and we agreed on a plan. Second part of your question you will need to new springs and new rods.
jpsuperman81 is offline   Reply With Quote
Old 09-24-2009, 09:54 AM   #3
Pitttbulll
Pitttbulll
Pitttbulll's Avatar
Thanks.
I'll discuss this with my speedshop when I drop it off for the procharger.
Hopefully, they can add this to the project and do it all at once.
My goal is to get my car into the 11's.
Hopefully, with these mods, that will get me there?
Old 09-24-2009, 10:17 AM   #4
BigFish
BigFish's Avatar
Drives: 1971 Z28
What was the $$$$$$$
BigFish is offline   Reply With Quote
Old 09-24-2009, 10:40 AM   #5
jpsuperman81
Yep I'm back!
My $$$$ haven't been finalized yet, I put a 1000 dollar deposit down. I'm doing everything but forced induction. Cam,ported heads, fast intake manifold, throttle body, underdrive pulleys, 160 thermo, cai, and tune. I have a member journal should have all this in about two weeks.
Old 09-24-2009, 10:41 AM   #6
Matt TuneTime
Drives: 2008 G8 gt / 2010 Camaro L99
Mast Stage 1 cam I went 12.2 @115 in 3000 ft air on stock tires and converter ..
Matt TuneTime is offline   Reply With Quote
Old 09-24-2009, 10:44 AM   #7
Pitttbulll
Pitttbulll
Pitttbulll's Avatar
The Procharger, install, and tune should run around $8300ish.
As far as the cam, I haven't discussed it with them yet, but from what I've been reading in the forums, $800-$1000 installed seems to be the norm.
Also, everyone is saying the gains are well worth the price!!
Old 09-24-2009, 11:20 AM   #8
duder4thgen
Drives: Bird
You can but your selection is going to be pretty limited. I know Mast is making cams that still use VVT, Compcams makes a cam phaser limiter kit, don't know if they are making cams for VVT, and I think at least one more shop I can't remember might be grinding cams to use VVT.
Honestly the VVT stuff is just starting to catch on, so your best bet is to call up someone like Mast or Comp and see what they recommend for your setup and goals.
Either that or just rip out all the VVT and AFM stuff and run a traditional LSX style cam. Just go one or the other, if you run a cam not specifically designed around VVT, you are going to have some serious PTV issues and pop the motor.
duder4thgen is offline   Reply With Quote
Old 09-24-2009, 02:48 PM   #9
RonC
Drives: 2010 2SS - RS
Comp Cams does have 4 different VVT grinds available for the 6.2L but are not AFM compatible. Here is a link;
http://www.compcams.com/Cam_Specs/Browse.aspx
You have to click on the selector above "Camshaft Family" and scroll down to select "GM Gen IV LS VVT"
RonC is offline   Reply With Quote
Old 09-24-2009, 10:20 PM   #10
madmaxx18
madmaxx18's Avatar
Drives: 07_tundra/08_zo6
Hey I was wondering if you bought a stage 1 cam from adm or texas speed do you need to get pushrods and springs or not? I notice everyone says that you need to.
madmaxx18 is offline   Reply With Quote
Old 09-25-2009, 06:41 AM   #11
Pitttbulll
Pitttbulll
Pitttbulll's Avatar
Thanks again for all of your input.
Definitely want to go with one that keeps the VVT so as not to cause any engine damage.
I planning on having the AFM tuned off during the procharger install.
I hate the popping and burbling it causes with the exhaust.
Old 09-25-2009, 12:30 PM   #12
wavrun2000
o come on
wavrun2000's Avatar
Drives: 06 GTO
A new cam is kind of like getting rid of VVT. It makes your cam great at high RPM and reasonable at low RPMs. That is why when you install a cam it sounds the way it does. So installing a new cam would be like installing the second step of a VVT cam all the time.
06 GTO with three pedals like it should be
wavrun2000 is offline   Reply With Quote
Old 09-27-2009, 10:58 AM   #13
Pitttbulll
Pitttbulll
Pitttbulll's Avatar
Thanks again for all the info.
I think I might just holdoff for now on the cam.
I'll talk to my speedshop and let them do some research into it and see what's best for me.
We can always add it later on down the road.
I'm sure we'll be busy enough tweaking the procharger to get the best results!!
Old 09-28-2009, 07:41 AM   #14
FTI-EDC
The stick man
FTI-EDC's Avatar
Drives: 2004 GTO - C5 'vert - SRX
A properly designed camshaft profile will wake up that engine with the ProCharger installed. Do this all at the same time.
I would highly recommend removing the VVT system with this type of application since the timing events are critical for the blower to work best and the VVT system may not like the constant movement of these events.
If you're interested in doing this up the right way, contact New Era Performance Parts in Rochester and use their VVT elimination kit and one of my blower grinds. Look what this type of camshaft package did for a G8GT turbo combination.
Ed
G8GT article in GMHTP magazine
PONY WARS
FTI-EDC is offline   Reply With Quote
LS3 CAM AND HEADERS DYNO ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 53 02-13-2016 07:15 PM
Cam basics CamaroSpike23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 76 11-25-2015 12:42 PM
Cam Vs. Cam Vs. Cam My First Camaro! Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 12-11-2010 02:54 AM
Camshaft Basics Milk 1027 Wiki 1 12-09-2009 01:00 AM
L99 TVS 1900 + Cam Dyno #'s ARE IN pharmd Forced Induction - V8 35 09-07-2009 05:36 AM
