Old 02-21-2016, 01:04 PM   #1
hou30guy
Drives: 2011 convertible 2ss/rs
kenne bell boost a pump hp rating for ss camaro
Whats the max hp rating for the boost a pump before switching over to a zl1 pump, thinking of do huron turbo kit with 550 to 650 whp goal
hou30guy is offline   Reply With Quote
Old 02-21-2016, 02:28 PM   #2
agent5
Drives: 2013 Camaro SS (+RS) + Hurst+ DME
I don't know if this helps but I got a boost pump with my Procharger I1 kit and it seems to supply the pressure needed to reach ~650 HP at the crank without any issues. It's usually adjustable how much voltage you can push at the pump but I don't know how much more it would go if you wanted 650 WHP.
agent5 is offline   Reply With Quote
Old 02-21-2016, 03:59 PM   #3
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
I wouldnt look at it as "what's the max hp the KB BAP is good for" its more about what you're putting the BAP on. On a stock pump, you will find a few different answers from different people, with different setups. I would do your fuel one time, and one time only. if your planning for 650 get a fuel system good to 1000whp. Ask me how I know.
Soon you will want more power and you will be right back in the same boat. Are you planning on SC or turbo?
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 02-21-2016, 04:17 PM   #4
UNRIVALED SS
UNRIVALED SS's Avatar
Drives: 2010 Camaro SS
Send a message via Yahoo to UNRIVALED SS
550 WHP or so is about the average max for the stock pump. The voltage booster will add some to that. For a Turbo car I would invest in a better fuel pump.
UNRIVALED SS is offline   Reply With Quote
Old 02-21-2016, 05:22 PM   #5
hou30guy
Ok kool will do a zl1 pump
