Old 02-21-2016, 05:45 PM   #1
dantemcc
Drives: 2017 1SS 1LE
Who was the genius who thought of this?
Had a few hours to burn in between loads and stopped by to check on The BEEast. For some reason his battery was dead. Dont understand why. So I had to try to jump him with my other car.
Who is the genious who thought it was best to put the flippin battery in the flippin trunk and make an owner do all this flippin work to flippin jump the flippin car?!? WHO?????
Rant over.
dantemcc is offline   Reply With Quote
Old 02-21-2016, 05:53 PM   #2
Caseyls3
Drives: 2011 Camaro SS/RS Convertible
There are remote posts under the hood.
2011 Camaro SS/RS Vert - Jewel Red Tintcoat, 6M, 231/247 Comp Cam, Kooks headers, Borla ATAK, ATI under drive pulley, Richmond 4.10s, LS9 clutch, Hurst shifter, BMR Springs
Caseyls3 is offline   Reply With Quote
Old 02-21-2016, 05:57 PM   #3
mustang50lx
Drives: 2015 SS
In the trunk is mild compared to some cars that have them in the inner fender, or under the drivers or passengers seats, or even Ford diesel E vans that have one of them under the van.
mustang50lx is offline   Reply With Quote
Old 02-21-2016, 05:58 PM   #4
witenite
witenite's Avatar
Drives: 2010 2SS non RS
witenite is offline   Reply With Quote
Old 02-21-2016, 06:02 PM   #5
Stewart
Stewart's Avatar
Drives: 2014 Camaro 2SS RS & Ground effects
Hopefully there will not be a next time, but if there is there is a positive post that is connected to your battery under the hood that is located in front of your brake fluid bottle. I have used that to jump cars a couple of times. Connected the ground to the stud that the air box was connected to. I also carry a jumper box in case I need it. I was told the reason for putting the battery in the trunk was weight distribution
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260
Stewart is offline   Reply With Quote
Old 02-21-2016, 06:03 PM   #6
Skillet
Drives: car
The battery in the trunk is a great idea. Saves space in the engine bay. There is a positive post and a ground post (actually two) in the engine bay. No need to access the battery in the trunk other than to change it if need be.
I guess even geniuses need to learn about the cars they bought.
Skillet is offline   Reply With Quote
Old 02-21-2016, 06:08 PM   #7
Stewart
Stewart's Avatar
I know and have used the positive post is but where is the ground post?
Old 02-21-2016, 06:10 PM   #8
Chris-10
Chris-10's Avatar
Drives: 2ss/rs vr 6m
That's a lot of flippins...
Old 02-21-2016, 06:12 PM   #9
Desert Dweller
Desert Dweller's Avatar
Drives: 2015 Z/28 #334
Owners Manual. Read it, learn it, remember it.
Makes for less work next time.
Desert Dweller is offline   Reply With Quote
Old 02-21-2016, 06:13 PM   #10
Deftones
Deftones's Avatar
Drives: 2012 RS/SS LS3
Inside of your CAI lid now
Deftones is offline   Reply With Quote
Old 02-21-2016, 06:14 PM   #11
Desert Dweller
Pretty much the entire chassis of the car, but any good metal point on the engine will work.
Old 02-21-2016, 06:16 PM   #12
PostNup
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99
Ground can be just about anywhere metal. I have grounded up by the radiators on previous cars before. Worked like a charm.
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires.
PostNup is offline   Reply With Quote
Old 02-21-2016, 06:24 PM   #13
Stewart
Stewart's Avatar
Thank you, I was not aware of that I appreciate the info.
Old 02-21-2016, 06:26 PM   #14
ghosted
BCS Auto
ghosted's Avatar
Drives: 2015 Camaro 1LS
Rant over.
Like other's have said, it was probably the same genius who put a positive terminal under the hood, along with negative posts (though you can ground to almost anything that's bare metal.)
Good job buddy.
BCS Auto on Facebook - - - Follow me on Instagram @datv6tho & @officialbcsauto
ghosted is offline   Reply With Quote
