Old 02-25-2016, 07:26 PM   #1
ROW DAWG 1LE
ROW DAWG 1LE's Avatar
Drives: Summit White 2015 1LE 2SS/RS
AGP TT kit recommendations
Hey.
I have 15 1LE that is bone stock.
I'm looking for some input on a set up with goals of making of making 700 rwhp. 700 isnt set in stone, it's just a number I liked.I could live with 6-650 if it's safe/reliable and not pushing the limits. I don't drive the car daily, but I would like to have that same feel. I don't track my vehicles or drag race, just a little street fun from time to time. I live in Washington state and 92 is the premium gas offered, I have read about e85 and meth setups, and I wouldn't mind doing meth and a safe tune since I'd like to stay on pump gas and not do anything to the stock bottom. I'm not loaded up with cash but I can afford to go with a little more than the base kit.
I hope I've painted a decent enough picture.
Any help is greatly appreciated.
ROW DAWG 1LE is offline   Reply With Quote
Old 02-25-2016, 07:53 PM   #2
cc-rider
Drives: 2010 Camaro SS
You're on the right track with the AGP turbo. They push out 700hp easily and everyone who owns one seems tickled with it. But you need to think hard about the E85. It requires a fair amount more money because of all the fuel capacity it requires. You're looking at a return style high volume fuel system and big injectors. It's probably about $1500 more. Maybe less. The guys at AGP can probably hook you up with everything right off the bat.
I think the base AGP kit can get you to 700 without E85. Especially with 92 octane. Decent fuel.
But there's something to be said for overbuilding your fuel system up front and only paying for it once.
cc-rider is offline   Reply With Quote
Old 02-25-2016, 08:12 PM   #3
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
Base kit should be all you need with the right fueling.
MODS:
Old 02-25-2016, 08:31 PM   #4
ROW DAWG 1LE
What would be considered an overbuilt fuel system over what I have now and what would come in the base kit? I'm definitely only interested in doing it one time.
Old 02-25-2016, 10:05 PM   #5
AGP Turbo
Drives: All things Turbocharged
We've got the whole package that will make 800whp on your 100% bone stock car, flex fuel enabled to switch between fuel at any time. Makes 700whp on pump and we stop at 800whp on E85 on stock LS3. Stock cam, stock exhaust etc.
Fuel system is dual 450's in tank, -8 feed, regulator under the hood and flex fuel sensor, etc. Will support 1000+whp on E85 later.
AGP Turbo is offline   Reply With Quote
Old 02-25-2016, 10:28 PM   #6
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
First of all, AGP rocks.
Buy as much fueling as you can afford. You will likely grow into it. I did LPE twin fuel pumps and ID-1000 injectors before I even knew I'd ever consider E85. Glad I did, got all fueling covered to maximize the potential of a stock rolling block now. BTW, I still have over 120rwhp untapped because of my stock internals. Wish I could up the boost but won't until forging happens.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 02-25-2016, 10:35 PM   #7
ROW DAWG 1LE
If you could PM me with some quotes on the setups you mentioned I'd be one step closer to making a deal
Old 02-25-2016, 11:18 PM   #8
Z21LE
Drives: 2006 Z06
Same boat as you, just waiting for my AGP kit to show up and then it's game time I went with the base kit. My goal for now is 550-600whp and then decide from there.
Z21LE is offline   Reply With Quote
Old 02-26-2016, 12:24 AM   #9
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
When it comes to fuel, go big, especially if your in the E85 market. If AGP says they have what you need, then id run with it. A Squash or fore setup will set you back more than 1500 not including injectors.
If your looking to make 700 then get a fueling system that will support 1000whp. Ask me how I know.
As for AGP, you gotta watch those guys, they like to help people and have a tendency to answer any and all questions. Oh yea, they make a killer product too. Just be carefull, the speed/horsepower bug can bite hard.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 02-26-2016, 12:39 AM   #10
Glushenij
Glushenij's Avatar
Drives: 2014 Camaro 2SS 1LE
I just put my kit on 2014 1le ( Efr 7670 full kit, with 850cc , methanol and Bap) car make 672whp 695wtq on 12psi with 75% methanol! Kevin give me price I can't refuse and answer over emails all my questions ! I install kit myself in 2 days!
AGP TT 807whp 811wtq 13.46psi E85+methanol
Glushenij is offline   Reply With Quote
Old 02-26-2016, 11:44 AM   #11
cc-rider
What I meant by $1500 I mentioned above was not that it was the total cost of the pump + injector. But rather it will probably cost him $1500 additional as compared to the base pump + injector set up that he will need anyway just for the base AGP kit.
What does AGP send out with their base kit for a pump and injector?
Old 02-26-2016, 12:56 PM   #12
Skogen
Hell Yea!
Skogen's Avatar
Drives: 1969 Chevelle SS & 2012 2SSRS M6
I would call Kevin at AGP. I know they have quite a few options to look at.
And 1KillerSS is 100% correct, it is a great kit with amazing results.
Look up my dyno on utube.
Life is like sex. If you are not having fun, you are doing it wrong!..
2012 Camaro 2SS/RS Crystal Red Tintcoat - AGP 54/57 Twin Turbo with Meth injection. 704 RWHP.
2015 Chevrolet 2500 LTZ
1969 Chevelle SS396 - Numbers matching
Skogen is offline   Reply With Quote
Old 02-26-2016, 02:07 PM   #13
ROW DAWG 1LE
That's exactly what I took away from what you wrote. If I'm not mistaken, my car should have come with the zl1 pump...so it was my intent to go with the msd bap, and from what I have seen playing around with different vendors offering the agp kit it looks to me like 850cc injectors.
I was planning on doing BB turbos, but now I'm thinking I should take that extra money and put it in a clutch or like others have said and build fuel.
Old 02-26-2016, 02:15 PM   #14
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
The first few lines I agree 100% with and if i could do it all over again I would of went bigger on the fuel system like they are recommending
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
