![]() Drives: 2014 Camaro Zl1 Tripple Black! Join Date: Nov 2014
Dynatech. Pfadt. Or American racing headers
I have done a lot of research and looking at one of these three options for my zl1. Looking at buying the JRE 125 package but not sold on the headers yet. I have researched old posts about all these systems.
Anyone have any advice on what headers? Quality? Performance? I youtubed some sound clips previously. I am leaving stock catback on. Thanks. |
![]() ![]() Drives: 2014 SIM 2SS Join Date: Sep 2015
Performance should be about the same for the different brands of longtubes. I called Janetty a few weeks ago to discuss headers for my SS and they recommended Dynatech. It sounded like they thought Dynatech was the easiest install/best fitting, and they liked the 4 bolt flange.
![]() Drives: 2012 ZL1 Join Date: Nov 2015
I've got Kooks 1 7/8 W/Cats and they fit perfectly and were stupid simple to install.
![]() ![]() ![]() Drives: 2010 Camaro SS Join Date: Dec 2006
All 3 you mentioned are great headers. Although I don't quite think that Dynatech are up to par with the others. The issue I always had with Dynatech is that they seem to hang really low and not tuck up as nicely as other headers. However, Dynatech has the new Supercats which mate up to their headers which are supposed to hold up to boost. I'm skeptical...but reports so far are good. The Pfadt headers tuck way up nicely and are a work of beauty. They have the tri-Y design and may offer you a bit more mid range power at the expense of a bit less top end power as compared to the others (which is great for street driving). But the differences are probably very small. And I think Pfadt fit in the ZL1 the best with no trimming of the belly pan at all (though this isn't a bid deal at all for the others). ARH has excellent quality. You may want to throw in Kooks as well. They are right up there with quality and features.
Or you could think of going with Texas Speed or Speed Engineering and get the same quality and results at 1/3 the price. I know Jannetty pushes Dynatech...he must get the best deal from them and make the most money there. They are certainly a good header and a good option. But there are others out there. If I was going to go expensive, I was going to go with the Pfadt headers. They are just beautiful and street power is what I want in my car. But in the end I went for Speed Engineering headers and got everything shipped to my door for $340. 304 stainless. Merge Spike. Great quality. 02 extensions. Off road pipes. All for $340. I took the $700 I saved by that decision and bought some other parts I wanted (ID1000 injectors!). Lots of good options. Be careful of the vendors pushing you around and scaring you into only their preferred option. Many, many great options to choose from. Good luck! |
![]() Drives: 2014 ZL1 Join Date: Sep 2012
I also went with Kooks headers. You don't have to trim the belly pan on 14-15 ZL1's
#6 |
Thanks for all the info.
Few more questions does American racing and kooks both have super cats that connect to stock catback? I would prefer not to change the catback. Also, I have read than even with stock catback it can be very loud if you don't use cats of some sort. Anyone have an issues with cats on any of these? I hear the Dynatech super cats work well. |
#7 |
Also do I have to do any trimming on my 2014 to install Dynatech ? Sounds like I don't but wanted to make sure.
Anyone have any dyno graphs or numbers on Dynatech? Found more info on the others. Curious about performance differences. |
#8 |
![]() Drives: 2013 VR ZL1 Join Date: Aug 2012
American Racing 2" primaries, Couldn't be happier
2013 ZL1 Victory Red - 628
2015 Chevy Silverado Midnight Ed. 6.2 1500 LTZ Z71 |
#9 | |
![]() ![]() ![]() ![]() ![]() Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
#10 | |
Just looking for the best headers. That's it. If I chose Dynatech then I will definitely buy from Ted as he had been absolutely excellent to work with. If I don't then I can piece the kit together and get a custom tune which will probably be a bit cheaper. Either way I want the best bang for the buck. Headers don't yield that much hp gain so to me it makes sense to buy the best ones in which yield most power and sound great. I have received some messages from people which Dynatech and they have been indifferent. Some good and some bad. Last edited by 370zyzfr1; 02-26-2016 at 08:09 PM. |
#11 |
![]() Drives: 2013 ZL1 Triple Black Vert M6 #5591 Join Date: May 2013
I'm happy with my setup. Dynatech ceramic coated with the super cats and the 125 package and some extras. Car runs flawless and sounds amazing. Just my .02. But I try not to worry to much amount the cost, considering all the money you spent on the CAR. I'm not a performance car expert so I have to pay for someone I trust and Ted is that guy. Thanks
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice.. |
#12 |
![]() Drives: 2013 AGM ZL1 BELLA* Join Date: Jan 2011
I was in this same delimma last year but ended up going with Dynatechs 2". I love them. Had them ceramic coated, work just fine. Saved a few $ in the process.
Roto Fab CAI, Roto Fab Big Gulp, Jokerz ported SC/Snout, LS7 TB ported, ATI Balancer, 28%(10") Lower Pulley, 2" Headers, No Cats,Forza 3way, E85 Flex Fuel sensor , ID850 injectors,, BTR Stage 3, Ron Davis HX, Mighty Mouse CC, APR Splitter, Aero Sports Concepts Splitter Kit, Showstoppers CarbonFiber wicker bill, MRR Wheels. 720rwhp/690tq on 93, 762rwhp E85.
2013 AGM ZL1 Bella* 2010 MGM Toyota Tacoma 2010 CGM SS (Traded) 1996 Black SS (Sold) |
#13 |
#14 |
I pulled the trigger with the JRE 125 kits exactly as offered by Ted. Little worried about the performance of the supercats but I trust Ted and his advice. He states that the supercats were engineer specifically for forced induction vehicles.
Can't wait to get it installed! |
