Old 02-29-2016, 07:28 AM   #1
Karlito
Karlito's Avatar
Drives: 5.7 Z28 2dr red Coupe (2001)
water issues !
Hey all!
I'm having issues with the loss of cool water for my 5.7 Z28 Coupe. Levels dropped last week but the water was clear looking. Then on Thursday I saw the water was a bit rusty, so I looked into the water tank and saw the same rusty a** water inside.
So I filled up on Thursday and went to work on friday. Again I see a dripping trail ... drive home 5 pm, and see the water indicator flashed on the dashboard. Again I refill with water this time I see the water temperature indicator rising and rising. I stopped at a gas station and checked the tank. It was quite full, but the engine was so damn hot that when I pulled out the dipstick I burned my finger on the plastic.
Is the flow of water blocked / the flow no longer functions. Is the water pump defective?
I took the bus to work today as I don't want to hurt the engine! Getting a bit worried this could be a costly repair, so if anyone has any ideas what it could be and if I can fix it myself that would be much appreciated !
the wall just got 10 feet bigger
Karlito is offline   Reply With Quote
Old 02-29-2016, 11:21 AM   #2
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
Probably got a air pocket trapped in the cooling system . I would take the car to a garage and have the cooling system bled and pressure tested . You need to find that leak.
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
