Old 03-01-2016, 12:57 PM   #1
Sdvolcom
Drives: 2010 5th gen camaro 2ss LS3
Nitrous electrical problem. Plz help.
Ok everybody. I am in desperate need of help. I have a NOS system with NX solenoids. The relay for the solenoids came with a 20 amp fuse. Originally we hooked up the power to a 10 amp fuse and we kept blowing fuses so then we put the power straight to the positive battery and we were still blowing fuses so whenever I try to do a test pass pop there goes another fuse. So if you guys could help me out and give me some advice I would really appreciate it
Sdvolcom is offline   Reply With Quote
Old 03-01-2016, 04:22 PM   #2
hazy
Drives: 2011 2SS/RS
I can't say that this will be the same, but I had an issue on my last motorcycle where I kept blowing a particular fuse. Turns out I had a hot wire that was grounding out and blowing the fuse. So, to that end, I'd say check ALL of your wiring to make sure none of it is exposed/touching/arcing
hazy is offline   Reply With Quote
electrical, help me, nitrous, nos, problems
