Old 03-01-2016, 07:03 PM   #1
Matt8892
Drives: 2010 2ss RS. White (RIP) 2012 LS3
Those who installed an MGW yourself... Did you lower the Trans?
Is it really necessary?the entire process of installing the mgw seems doable, with the exception of lowering that Trans. That part has me nervous. When I installed my hurst, it said to lower the cross member for the Trans, but I didn't even do that. I'm about to bite the bullet and order the mgw.
Any tips or suggestions for the install. It definitely looks more involved than the hurst, but doesn't necessarily look harder.
Matt8892 is offline   Reply With Quote
Old 03-01-2016, 07:46 PM   #2
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Nope didn't lower the trans, but I am a V6 car so I am not sure if the 6060 has less room than my AY6. Just followed the video and it went smoothly. Have driven quite a few different performance manuals and the MGW is one of my favorite shifters.
Old 03-01-2016, 07:53 PM   #3
Matt8892
Hmm ok. I would imagine the v8 Trans has more but to it. But in theory it seems super simple to reach up there, release the clip, pull the bolt out, and reverse. That's really the only part that's got me worried. The rest can be harder than getting the stupid screws in for the hurst in that tight area
Old 03-01-2016, 08:18 PM   #4
clarkkent
Drives: 2013 2SS (sold)
I lowered the trans, it was much easier getting things up/down from there. If I recall, it's very difficult/you can't get the stock shifter out of there without lowering the transmission
clarkkent is offline   Reply With Quote
Old 03-01-2016, 08:23 PM   #5
Matt8892
Please tell me it's not as bad as it sounds.... The video shows the brace and a few bolts in the center of that loosened. But I don't have a pole jack to ease it down and back up. And I would be doing this on the ground.
But I really don't wanna pay someone to do it. I love doing stuff myself.
Old 03-01-2016, 09:19 PM   #6
clarkkent
It was pretty easy, I was doing mine on a lift and had one of those large pyramid lift stand things.
In hindsight it may be ok without one, the driveshaft held it up ok
Old 03-01-2016, 09:29 PM   #7
Matt8892
Oh boy. That does not sound like something I want to do anymore. I really don't wanna screw something up. I'm scared.
Old 03-01-2016, 09:41 PM   #8
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Yes I did. You have to lower than trans to get the shifter body out. It's really really simple. I did my install on jackstands and lifted and lowered the trans with a 2 ton floor jack. Followed the MGW video step by step.
Problems I had, the linkage pin didn't fit well and had to be forced into the shifter shaft. The bolt/screw things, didn't have enough room to back out, was a pain.
Well worth the time and money.
CamaroDreams76 is online now   Reply With Quote
Old 03-01-2016, 09:58 PM   #9
FunkedOut
FunkedOut's Avatar
Drives: Black 2010 SS
i did it on a lift and didn't use a jack on the trans.
the original mgw video never mentioned holding up the trans, so i didn't. the motor and driveshaft held it up fine.
if you're worried, buy an extra cheap jack. an extra jack comes in handy a lot.
FunkedOut is offline   Reply With Quote
Old 03-01-2016, 10:46 PM   #10
Matt8892
Well if I put the car on ramps, and the rear end on stands, I can use my jack on the Trans.
Old 03-02-2016, 12:29 AM   #11
FunkedOut
FunkedOut's Avatar
if you're gonna put the front on ramps and jack the rear, make sure you chock the rear of the front wheels.
I like a spare set of jack stands under it too.
Old 03-02-2016, 08:51 AM   #12
BurnedRubber
Ben Rakers
BurnedRubber's Avatar
Drives: 2011 Camaro 2SS/RS
i lowered the trans slightly for mine, made it possible to get the pins out of the trans for the mount. i just put the car on jack stands and used my floor jack to slowly lower the trans until i could get access. without lowering it the pins didn't fit out in that part of the trans tunnel for me.
2011 Camaro 2SS/RS K&N Blackhawk Cold air intake, Hawk Performance Ceramic pads, BAER drilled and slotted rotors, Side louver black faded inserts, Hurst Short Throw Shifter, BMR Trailing Arms, Elite Engineering Catch Can, MSD Spark Plug Wires, Texas Speed 1 7/8in Headers and cat back, High Flow Cats, 3 inch X-Pipe, Speed Dawg shift knob, Tuned by Nickey. And oh, its My first car.
https://www.youtube.com/channel/UC_L...5jF6EQEoKDNQ2g
BurnedRubber is offline   Reply With Quote
Old 03-02-2016, 09:34 AM   #13
BostiPB
BostiPB's Avatar
Drives: 2014 Camaro 2SS/RS
I lowered mine when I did it. I had my car up on ramps and went and bought a trans jack for under $100. Being on the floor was a bit of a pain but it is doable. The hardest part I had was with the clips that hold the arms of the shifter on. Those were the biggest PIA.
2014 2SS/RS - Red Rock Metallic - Kooks Headers, Corsa Extreme, Factory Reproductions Z28 Rims, Pedders Coilovers, JDP Clutch Reservoir, Summit Racing Line Lock, GM Strut Brace, GM low profile splash guards, Roto-fab CAI, Oracle Ghosted Sidemarker Lights & Concept Mirrors, ZL1 Side Skirts, MGW Flat Stick Shifter, BMR Subframe Connectors, Eaton Truetrac, Yukon 4.11s, GForce Renegade Axles, Speedmaster79 Diff Cover, Offset Diff Bushings, Every Suspension Bushing Front & Rear Replaced with BMR Poly Bushings - 421HP 412TQ
BostiPB is offline   Reply With Quote
Old 03-02-2016, 09:57 AM   #14
NC_SS
NC_SS's Avatar
Drives: 2012 M6 Camaro SS (RIP)
I lowered my trans crossmember when I installed my hurst short throw shifter.
It's a pain to get around the TR-6060, so I'd recommend lowering it a little.
NC_SS is offline   Reply With Quote
