![]() ![]() Drives: 2015 1SS, 1LE, Recaro, NPP Join Date: Apr 2014
Just got tuned on C16
I had my stand alone fuel cell installed today and got it tuned for C16. Not only is it much safer, but I also picked up 20rwhp, so I'm pretty excited. I'm picking the car up tomorrow, and I'll post some pictures of everything.
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor) 647 RWHP 723 RWTQ (150 Shot) 12.1 @ 117 (Motor) 11.7 @ 129 (Nitrous) Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports Youtube Channel: Click Here |
Master Amateur Mechanic
Drives: Victory Red 2011 2SS/RS Join Date: Jan 2013
I'm new to the term c16, is it some type of nos infused gasoline?
2011 Victory Red 22/RS
Forged 418 Ls3 from Texas Speed, LSX heads from Texas Speed, Tick Turbo cam, Jakes/PCM/Billet 4l80e, 3200 Stall converter from Circle D, DSS 750 hp axles, DSS aluminum driveshaft, stock 3.23 gears, TSW Wheels Front 20x10 Rear 20x11.5, Fabberage Twin Turbo Supercharger Killer kit with Upgraded Turbos, Squash Dual fuel pump, Full BMR Suspension/bushings, Holly High Rise intake manifold, ID1300 Injectors, Megan Coilovers, PCM of NC plug and play trans kit. HP/TQ TBA |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
It is a leaded fuel that is 116 octane. It has a greater resistance to detonation. He probably was able to add timing giving the power gain.
#6 |
Yes, we were able to add timing.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
The catch... What is the cost of c16 these days? I would have gone flex fuel e85..
#8 | |
I only use it when I spray so it'll last me a while.
#9 |
Drives: 2010 2SS/RS Join Date: Jun 2009
#10 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
Nice man, did the standalone help with the dreaded lean spike when nitrous engauges?
#11 |
![]() ![]() Drives: 2015 Camaro SS 1LE, 2001 Camaro SS Join Date: Jun 2015
How much timing are you pulling now?
2017 GMC Canyon All Terrain- daily driver/dirt bike hauler
2015 Camaro SS 1LE- sold 2001 Camaro SS SOM M6- sold 1999 Firebird Formula A4- sold |
#12 |
Thank you. Yes it helped out a lot!
#13 |
We just added 1 degree, so I have 5 degrees pulled
#14 |
![]() Drives: 2015 CAMARO 1LE Join Date: Oct 2010
Understand the majority of your fuel still comes from your injectors using whats in your tank, people overlook that. Your overall octane is not even close to the c16 in the cell. I've seen many head gaskets blown this way by people not understanding and tuning too aggressive. Just something to keep an eye on.
2015 CAMARO 1LE
