Old 03-02-2016, 12:03 PM   #1
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
3.91 gears questions
I'm planning on having 3.91 gears installed on my car once I know we won't have any more rain (hopefully soon). I saw the gears on phastek for $309.95, and the install kit for another $200. Do I need the install kit? What does it do? How much should I expect to pay for labor? Will it improve my 0-60, and by how much? Thanks for your input everyone
SynergyGreenSS is offline   Reply With Quote
Old 03-02-2016, 12:14 PM   #2
Dmpsix
Dmpsix's Avatar
Drives: Black L99 2SS/RS
http://www.camaro5.com/forums/showthread.php?t=281654
Originally Posted by biggerisbetter View Post
$1000 bucks ish. if i was going to do it again i would order the gears from jannetty racing i think the 1le gears are $350 ( http://www.jreperformanceparts.com/2010-2013-camaro-ls3-gm-1le-3-91-gears.html ) and ted will update the tune for free (a $315 value). i found a custom trans shop local that said if i remove the diff and bring it all to him he would install for 400 bucks. so for 750 you could have your gears installed and tuned. if i wanted the guy to do all the work he said it would be 700 for the install. just shop around i got qouted from 400 - 2500 haha the high end was the dealer
Dmpsix is offline   Reply With Quote
Old 03-03-2016, 11:32 AM   #3
asmith
asmith's Avatar
Drives: 2015 SS Camaro
Do your self a favor and avoid after market gears, GM gears are nominal and chances of winding up with a howler are greatly reduced.....
https://chevroletperformanceparts.co...r-kit-19301504
2015 2SS/RS Crystal Red, Z28 CAI, Borla S Type axle back exhaust, LE Gear upgrade.
asmith is offline   Reply With Quote
Old 03-03-2016, 12:17 PM   #4
TXM62SS
TXM62SS's Avatar
Drives: 2012 2SS/RS LS3
Exactly
Victory Red 2012 2SS/RS LS3 Camaro
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA
Kooks 1-7/8" LTs w/ Cats
Roto-Fab, Bo White TB, Borla Touring Catback
3.91 1LE Gears, MGW
Tuned by Pat G
TXM62SS is offline   Reply With Quote
Old 03-03-2016, 01:33 PM   #5
SynergyGreenSS
Drives: 2011 2SS
I was planning on getting oem gears and having them installed at the dealership
Old 03-03-2016, 01:53 PM   #6
blakjak55
drinks virgil's
blakjak55's Avatar
Drives: 2010 2SS M6
Can't speak for 0-60 as I haven't measured. Seat of the pants is definite.
Not sure if the Phastek kit comes with the speedometer recal code or not either. The GM kit comes with one or if you get it through Janetty apparently he can do it as well.
Cheapest route is to buy the gears and install yourself. If you can't, then pull the pumpkin and take it tome someone to install and put the pumpkin back in yourself. If you can't do that either, the dealer is going to cost you $1500 or so for everything.
2010 2SS/RS M6 - CAI Intake - Borla Stinger - VTC - 3.91's
Eibach Sways - LG ZR28's - BMR Springs - 285/35 Squared
blakjak55 is offline   Reply With Quote
Old 03-03-2016, 02:31 PM   #7
SynergyGreenSS
Drives: 2011 2SS
Seems pretty unreasonable.. My dad is a divorce attorney and he's handling a case for the owner of a performance shop in my town so maybe he'll give me a deal..
Old 03-03-2016, 02:41 PM   #8
blakjak55
drinks virgil's
blakjak55's Avatar
Drives: 2010 2SS M6
Hahahaha yeah maybe. It's the labor that kills.
It's not hard to pull the pumpkin and take it someone. Just make sure they set the preload to spec and the backlash is good.
Old 03-03-2016, 04:34 PM   #9
SynergyGreenSS
Drives: 2011 2SS
Sounds good. Thanks for the advice
Old 03-03-2016, 08:04 PM   #10
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Got my set from Muareen from Rodgers Chevrolet best price anywhere!!!
Orange Krush II
Old 03-03-2016, 08:28 PM   #11
christianchevell
old school chevy rodder
christianchevell's Avatar
the kit is for the new bolts sometimes needed for the differential and the shims that are necessary to install to adjust it just right also new bearings are good, as is a LPW diff cover and poly bushings for the diff at least with the rear.
Old 03-03-2016, 08:44 PM   #12
SynergyGreenSS
Drives: 2011 2SS
Thanks for the info!
Old 03-03-2016, 11:29 PM   #13
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
I had a gear shop do it. I just gave them the pumpkin. had less than $700 in it all new GM parts
JCunningham is offline   Reply With Quote
Old 08-11-2016, 08:45 AM   #14
fastbroshi
fastbroshi's Avatar
Drives: 2010 Camaro SS
I just had a shop give me a quote and they said with my mileage, 59k, I might want to do the bearings as well. What bearings is he talking about? All I see in this kit are shims/spacers and a crush sleeve.
fastbroshi is offline   Reply With Quote
0-60, 3.91 gears, 3.91 kit, gear swap, gears
