Old 03-03-2016, 11:02 AM   #1
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
Dyno tune vs agp base tune
Not sure if anyone will have the answer but I'll ask it anyways, I am currently running agp tt kit my kit includes the following- 850cc injectors, MSD Voltage Booster, Turbos are 54/57 JournalBearing --- .63 a/r 800whp (FAST spooling), my question is how much power am I leaving if any on the table running the agp base tune vs a dyno tune?
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 03-03-2016, 11:36 AM   #2
Cool AirZ28
Cool AirZ28's Avatar
Drives: 2013 Black Camaro 2SS/RS Convert.
Guys that I know who are running the AGP kit that used the base tune at first then went and got a dyno tune said the base tune was pretty much spot on. They gained a few ponies but nothing major
2013 Camaro 2SS/RS-Smoked tail lights and side markers, HID log lights, & LED lighting inside/outside the car, SJM LED Cupholder, SJM full dashboard ABL lighting, ZL1 Rockers, 1LE Splitter, Showstopper LED Mirrors, Showstopper LED Side Markers, & Showstopper Heat Extractor Hood, 20" Niche Concourse ZL1 Styled wheels 20X8.5 & 20X10 with 275/40/20 & 315/35/20 Nitto Invos, Black Gorilla Lug Nuts/Locks, Black Billet Elite Camaro License Plate Holder, and Hydro Dipped Speedo/Shifter/AC-Heat Bezels.
Cool AirZ28 is offline   Reply With Quote
Old 03-03-2016, 12:26 PM   #3
Unreal
Drives: 2006 Z06
Hard to say. Base tune definately isn't setup for 5k+ elevation, and is way safe. Could be 10hp or 150hp. Being in CO, I would get it tuned asap. And don't worry about a dyno tune, just get a local tune. IMO street tune is far superior to a dyno tune. That concepts is so blown out of proportion.
Nick
Corvette Z06 -1200ish rwhp
Old 03-03-2016, 12:57 PM   #4
Moreair1
Moreair1's Avatar
What do you think of email tune's like I see advertised form a couple sponsors on the board, I ask since the closest shop is around 3 1/2 hours away and haven't really heard great things about the shops and thank you all for your advice.
Old 03-03-2016, 01:12 PM   #5
Unreal
Drives: 2006 Z06
Depends on the tuner. Matt@FSP, great tunes through email. Others, not so much.
As long as they are going to look at logs and then adjust, that is no different than a dyno tune.
Nick
Old 03-03-2016, 01:12 PM   #6
DaFisch
Master Amateur Mechanic
DaFisch's Avatar
Drives: Victory Red 2011 2SS/RS
some people on here do some good work with the order Tunes. I'd definitely do some research and try it out. They'll work with you too to dial it in correctly if they are reputable.
2011 Victory Red 22/RS
Forged 418 Ls3 from Texas Speed, LSX heads from Texas Speed, Tick Turbo cam, Jakes/PCM/Billet 4l80e, 3200 Stall converter from Circle D, DSS 750 hp axles, DSS aluminum driveshaft, stock 3.23 gears, TSW Wheels Front 20x10 Rear 20x11.5, Fabberage Twin Turbo Supercharger Killer kit with Upgraded Turbos, Squash Dual fuel pump, Full BMR Suspension/bushings, Holly High Rise intake manifold, ID1300 Injectors, Megan Coilovers, PCM of NC plug and play trans kit. HP/TQ TBA
DaFisch is offline   Reply With Quote
Old 03-03-2016, 01:45 PM   #7
flyer08
Drives: 2010 2SS/RS
You won't have issues with a mail ordered tune if you can log afr and other data they need to see to make adjustments.
Well, as long as they know what they are doing
flyer08 is offline   Reply With Quote
Old 03-03-2016, 01:55 PM   #8
camaro692
Drives: 2010 Camaro SS, G8 GT, HD FLHRX
I am also in Colorado and looking for a good tuner for the AGP kit. Subscribed for ideas
[SIGPIC][/SIGP
camaro692 is offline   Reply With Quote
Old 03-03-2016, 04:05 PM   #9
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
+1 for Matt from FSP, he can get it dead on VIA email. He did mine.
If you have an AFR gauge, best way to see what kind of power your leaving on the table is to tell us your AFR. That is one of the best way I know if to judge how a car is performing.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 03-03-2016, 09:34 PM   #10
Moreair1
Moreair1's Avatar
What all did Matt from fsp need to do your email tune? and is it an issue that I have the standard hp tuner?
Old 03-03-2016, 10:44 PM   #11
1KillerSS
1KillerSS's Avatar
The issue with you having the standard HPT version is, you cannot log AFR from your AFR gauge.......It can be done using the AC input, but that is for version 2.24 not 2.25. Not to mention, even if you were to use version 2.24 and used your AC input to log your AFR. Matt wouldn't be able to see your data. You would have to take screenshots of your logs, and email them to him. Without wideband AFR, you would have to use fuel trims. Best thing is to contact Matt, and ask him what he prefers to do. I can show you how to use your AC input to log your AFR. In the past Matt has used screenshots, of data and tuned accordingly, using the AC input, but it was a PITA, and I don't know if he would be willing to do that again. Hontestly, I would send yours into HPT and pay for the upgrade. That way you can data log wideband AFR.
Build thread
Old 03-03-2016, 10:56 PM   #12
cc-rider
Good lesson here from 1KillerSS. If you're going to get the HP Tuners suite...get the Pro so you can hook up a wideband. The extra $$'s are insignificant.
cc-rider is offline   Reply With Quote
Old 03-04-2016, 12:08 AM   #13
Moreair1
Moreair1's Avatar
Ok thank you I have been pondering on upgrading my hp tuner for two reasons, one so I could data log and the second being so I could learn some about tuning
Old 03-04-2016, 04:25 AM   #14
1KillerSS
1KillerSS's Avatar
Dont get me wrong, you can log your AFR using HPT standard, VCM 2.24.
But like I said, nobody will be able to view your AFR data, but you. It will show as an unsupported parameter, when being viewed on a computer that wasn't used to actually do the datalogging. Plus with HPT switching to VCM 2.25 or now its called V3, who knows if you can even log your AC input with the new stuff. Spend the money and send it into HPT for the Pro upgrade. Well worth the money.
Build thread
