I ordered ECS Kit from Chris at East Coast, who was great to work with by the way. Included with the kit I ordered Alky Control Meth kit with AIS trunk kit single nozzle. My understanding is the single nozzle supports up to 650hp and with other mods of the car I hope to be flirting with that line. Should I just jump up to twin nozzles for the extra $75. Or would that be counter productive? Those that have exp. with this, please let me know your thoughts? Thanks.
Too much is never enough!
I was 750whp with only single nozzle. If your going to be below that, single is fine, above that, and dual nozzle is prefered.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2006 Z06 Join Date: Oct 2010
Single is fine up to ~800-850rwhp.
Nick
Corvette Z06 -1200ish rwhp |
2010 transformer
Drives: 2010 ss camaro Join Date: Nov 2014
What about three 1 before the head unit
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
Thanks guys. Just realized how simple the concept was with a T and an additional nozzle. I'll just do it now.
#6 |
![]() ![]() ![]() Drives: 2011 2SS Convertible Supercharged Join Date: Nov 2010
You only need a single.
#7 |
![]() Drives: 2007 Corvette C6 983 RWHP Join Date: Dec 2011
The single is a 15 gph nozzle. The dual will add a 10 to that and is too much for 700 rwhp. Too much is as bad as not enough. What you can do is order a 5 gph nozzle, and use it with the 10. That way you have the same capacity as the single nozzle, using 2 nozzles. If you add power later on its just a matter of changing out for the bigger nozzle, when needed.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam YSI / 3.0 pulley, ARH 1 7/8 headers, NPP Dewitts / dual spals, A&A dual pump fuel system. 3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me. ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper Circle D Triple Disc stall 1009 RWHP @ 7000, 817 RWTQ @ 6000, |
#8 |
Or not waste the money now, and pay the $50 later to add the 2nd when you need it.
Nick
#9 | |
LOL. Or that, but he seems intent on having duals.
