View Poll Results: What traction control mode do you launch in
Traction control on 3 3.75%
Traction control off 11 13.75%
Competitive driving mode 21 26.25%
All Nannies OFF 45 56.25%
Voters: 80. You may not vote on this poll
Old 03-03-2016, 08:47 PM   #1
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
Competition Mode, Traction Control Off, or All Nannies OFF?
M6 guys only, how do you get your best 60ft? I know the norm is having all the nannies off. Has anyone had better results on a different mode?
booneSS13 is offline   Reply With Quote
Old 03-08-2016, 03:04 PM   #2
Vman75
Vman75's Avatar
Drives: 2011 2SS/RS
I've ran in Competitive Mode and my 60ft wasnt anything to brag about. With TC on, it bogged down to much, but i only tried it once. Next time I go I plan on running nannies off. If I can ever get back out to the track between rain and work.
Vman75 is offline   Reply With Quote
Old 03-10-2016, 09:33 AM   #3
GoldCartridgeGamer
GoldCartridgeGamer's Avatar
Drives: 2014 Ford SVT Raptor SuperCrew
In my A6 I run all nannies off if that helps any. I know it is not a M6, but might help.
Phoenix (sold)
How to hug your camaro
Buy the car that you would most like to get beat in. The other guy will always be faster.
GoldCartridgeGamer is offline   Reply With Quote
Old 03-10-2016, 06:56 PM   #4
booneSS13
booneSS13's Avatar
I got my best time slipping the clutch at about 5k rpm on bolt ons with drag radials. I had all the nannies off. I'll be at high hp level so I always wondered if the stabilitrac would help with the wheel spin at all
Old 03-10-2016, 09:50 PM   #5
jrhagen
Banned
Drives: Camaro
All nannies off, 1500 rpm launch, slicks and skinnies.
Best 60' so far is 1.59.
jrhagen is offline   Reply With Quote
Old 03-10-2016, 11:18 PM   #6
Motorboy8769
Drives: 2015 2ss
Is that on stock axles?
Motorboy8769 is offline   Reply With Quote
Old 03-11-2016, 10:09 AM   #7
jrhagen
Banned
Drives: Camaro
I back halfed my SS with all ZL1 and BMR parts. Axles are ZL1.
Old 03-11-2016, 02:26 PM   #8
Motorboy8769
Drives: 2015 2ss
Oh ok. If you don't mind me asking how much does a set of stock zl1 axles cost. Are you auto or manual?
Old 03-11-2016, 03:29 PM   #9
JakeW1990
JakeW1990's Avatar
Drives: 2010 Camaro RS/2SS
I've tried and tested this. The less help you have the better off you are when attempting a straight line shot at a TRACK with proper tires. Otherwise, Comp mode would probably be best for street.
Nannies off at strip, M6, bolt-ons = 1.6 60'
Comp mode at strip, M6, bolt-ons = 1.9 60'
Although Comp mode is less severe than full nannies, it does still have TC and will not allow burnouts and strong launches. I have videos of my learning of the TC system on the car and it's a whole other animal with good tires and nannies off.
2010 Camaro 2SS/RS M6
12.08 @ 115 - 9/2015 (392hp/393tq) NA w/ Exhaust + Tune
11/2015 (464hp/439tq) ^ + BTR Stage 4 w/ Halltech CAI
Engine: BTR Stage 4 Cam; BTR Dual Spring Kit; C7R Chain; LS2 Tensioner; High Volume Oil Pump
Drivetrain: ACT T2S-G05 x2 Disc XT Street Kit
Exhaust: Kook's 1 7/8" Headers w/ Off-road pipes;Kook's 3" cat-back; QTP 3" cut-outs
Suspension: BMR 1.4" Front & 1.5" Rear Springs; Blackdog Solid Mounts w/ Poly Bushings
JakeW1990 is offline   Reply With Quote
Old 03-11-2016, 04:37 PM   #10
jrhagen
Banned
Drives: Camaro
I bought all the ZL1 stuff as a set, so I have no idea what the axles cost. I am M6.
Old 03-11-2016, 05:06 PM   #11
booneSS13
booneSS13's Avatar
That's a nice 60'. Was that on 20's? Can you post a link to the video?
Old 03-12-2016, 06:29 PM   #12
hillshooter
Drives: 2015 Camaro SS commemorative
Great thread!
hillshooter is offline   Reply With Quote
Old 03-24-2016, 10:46 PM   #13
ASimmons04
Drives: 2015 AGM 2SS RS 1LE
This may be a dumb question but how do you do "nannies off"? I've run in competitive mode and when I shift to second it's almost as if the car hesitates and then goes. I ran with TC off and didn't get much better. My best time so far, STOCK everything, is a 13.7 at 107 mph. Tire pressure has not been touched since I picked it up brand new so I'm sure it's very high. Thought about lowering the pressure a bit to see if that helps. The factory F1's are definitely sticky.
ASimmons04 is offline   Reply With Quote
Old 03-24-2016, 10:50 PM   #14
jrhagen
Banned
Drives: Camaro
Hold the TC button for a 10 count. Now you are in control of the car.
drag time 1/4 mile help, launch control, launching, manual transmission, stick shift
