Old 03-04-2016, 10:38 PM   #1
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
Question McLeod RST VS. Street Slayer
Which one would you guys say is better for street/strip use with 650+rwhp? How much life should you get out of both for those of you who have experience with them?
booneSS13 is offline   Reply With Quote
Old 03-06-2016, 12:23 AM   #2
j.curt
Drives: 2017 Camaro 1SS
I don't know much about clutches. I just bought a McLeod RXT but haven't installed yet. Still trying to figure out what bearing I need.
There are two street slayer clutches for sale on here for $1200 I believe. One is a twin disc and one is a triple disc.
j.curt is offline   Reply With Quote
Old 03-06-2016, 09:14 AM   #3
07-SRT
07-SRT's Avatar
Drives: 2022 Camaro SS 1LE
I have the Mcleod RST for about 800 miles now. Its a little noisy at idle and engages near the top of the pedal. I"m only at 465/430 SAE rwhp though so im sure it will hold up fine for me.
2022 Camaro SS 1LE
07-SRT is offline   Reply With Quote
Old 03-07-2016, 11:01 AM   #4
Js2fst
2010 transformer
Js2fst's Avatar
Drives: 2010 ss camaro
A lot of people that they would have done the street slayer first they are expensive I did the 3 disk with speed bleeder and tilton adjustable slave. We will wait and see goes in after new fuel system
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
Js2fst is offline   Reply With Quote
Old 03-07-2016, 12:08 PM   #5
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
FWIW: I have the Triple Carbon Street Slayer. Bought it USED. Thought it looked good before install. Lesson learned as I should have sent it back to Thomas for inspection and perhaps a rebuild (my mistake - I personally would never buy a used clutch again without manufacturer inspection and refurb). That being said, I got a good year's running hard at the strip and it DOES hold the power. No complaints in that department. As for street? When I first installed it, it chattered and engaged mid-pedal. After beating on it, it is fairly smooth but now engages at the top of pedal. It's grabby. It's going to be pulled and sent in for rebuild and I'm expecting to get 3+ years of hard use out of it (like some others who have my same driving habits). Lessons: Yes, buy a SS but not used. Would I go SS again - yes. Have I tried anything else - no. Have heard good things about Monster.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 03-09-2016, 04:36 AM   #6
ken53007
ken53007's Avatar
Drives: 2010 camaro ss
How much does it cost to rebuild the street slayer?
ken53007 is offline   Reply With Quote
Old 03-09-2016, 12:58 PM   #7
CyberPredator
50 Shades of Prey
Drives: TT/SS
Depends on which one. I believe the rebuild for the triple is 1800.
OP Both of these clutches drive well, but it really depends on your end goal as far as power. I put my Street Slayer Triple in July of 2012 and since I have put 25,000 miles on it. Activation is at the top, Pedal is firm, but not abusively stiff. As long as the fluid is fresh activation is smooth and chatter free. (I advise doing a speed bleeder at the same time) The clutch does make a little noise when depressed, but quieter than most multi disc clutches I have driven. When I put this Triple in I was at 700whp and now I'm over 1000whp and it has been great.
I have a friend with an RXT and he's making 875whp with no issues. Activates a little lower than my clutch but higher than stock. Pedal is a about the same. ( His may be slightly softer) He has 6,000 miles on his and all is well with it.
Both are great clutches.
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 03-10-2016, 01:37 AM   #8
ken53007
ken53007's Avatar
Which slave cylinder should I go with? My throw out bearing is making a noise
Old 03-10-2016, 01:44 AM   #9
ken53007
ken53007's Avatar
One more question do I have to use hendrix engineering to get it rebuilt or can I go somewhere else?
Old 03-10-2016, 02:09 AM   #10
2012LS3VERT
Drives: 2012 2SSRS Vert, Black w/M6
The stock slave is fine, the Street Slayer comes with a billet support and new, heavier duty bearing that works with the stock slave. I have the twin carbon. The Street Slayer is made by RPS clutches, a big name in the clutch game, but going through Hendrix is the way to go. He has handled so many sales and rebuilds, he will get it done right every time. The Street Slayer is his brand name for the Camaro clutch.
2012LS3VERT is offline   Reply With Quote
Old 03-10-2016, 03:30 AM   #11
booneSS13
booneSS13's Avatar
I was told by Thomas at Hendrix that it's $1200 to rebuild the street slayer twin carbon
Old 03-10-2016, 03:31 AM   #12
booneSS13
booneSS13's Avatar
reading this just made me feel even better about my decision not to go used!
clutch, flywheel, twin carbon, twin disc clutch, versus
