Old 03-05-2016, 01:19 AM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
tps wire for window switch
OK so I need to know what wire to tap into for my TPS so i can set up my nitrous express window switch.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 03-05-2016, 01:29 AM   #2
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
If you're looking for the 0-5 Volt output. Tag the gas pedal. I believe it's a light blue wire, it's been a while since I did mine
ttshovel is offline   Reply With Quote
Old 03-05-2016, 01:47 AM   #3
damian559
damian559's Avatar
Drives: 2015 1SS, 1LE, Recaro, NPP
Yeah it's the light blue wire.
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor)
647 RWHP 723 RWTQ (150 Shot)
12.1 @ 117 (Motor)
11.7 @ 129 (Nitrous)
Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports
Youtube Channel:
Click Here
damian559 is offline   Reply With Quote
Old 03-05-2016, 04:08 AM   #4
2010_camaro
I found a purple wire on the throttle body.
