Old 03-05-2016, 10:11 AM   #1
Matt8892
Drives: 2010 2ss RS. White (RIP) 2012 LS3
How do you guys pull onto ramps... ?
I'm trying to pull onto rhino ramps to do my headers and the ramps just keep sliding out from under my tires. No matter how slow or quick I try going. And my jack doesn't get the car high enough to just lift it onto the ramps.
Any suggestions? Hopefully the headers go easier than getting the damn car in the air....
Matt8892 is offline   Reply With Quote
Old 03-05-2016, 10:24 AM   #2
miller8907
miller8907's Avatar
Drives: 2014 1SS/RS LS3
Are your tires hitting the ramps or your bumper. With my ramps, I have to drive onto a 2"x6" board and then the ramps so my bumper doesn't hit the ramps. If that's not the case then maybe try to block the ramps with something so they don't slide.
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
miller8907 is offline   Reply With Quote
Old 03-05-2016, 10:32 AM   #3
xrivera91
xrivera91's Avatar
Drives: 2015 Camaro 2ss
I have Rhino ramps as well and what helped was when I did my ground effects I removed that weird flap that hangs off the bottom because it made contact with the ramp causing it to move forward. When it came time to do the headers I had no issue.
xrivera91 is offline   Reply With Quote
Old 03-05-2016, 10:33 AM   #4
Matt8892
Nothing on the body was hitting. They were just sliding when I got about half way up. So I put a drop cloth under the ramps and voila, no more sliding. I am now up on the ramps. Thanks guys!
Old 03-05-2016, 10:37 AM   #5
xrivera91
xrivera91's Avatar
Great! Good luck on the install. Had to cut mine off as I couldn't get them out. Lol
Old 03-05-2016, 10:51 AM   #6
Matt8892
Oh God. I'm not doing that shit. Hahaha
Old 03-05-2016, 11:14 AM   #7
xrivera91
xrivera91's Avatar
Lmao if you can manage to remove the cats from the stock headers it might make it easier if not it's either cutting or getting a jack with a 24" extension lol.
Old 03-05-2016, 02:14 PM   #8
Matt8892
Well I've done the driver side successfully. Onto the passenger now
Old 03-05-2016, 02:53 PM   #9
xrivera91
xrivera91's Avatar
Great! Don't forget video afterwards
Old 03-05-2016, 04:51 PM   #10
Jack13SS
Jack13SS's Avatar
Drives: 2013 Camaro SS L99
How difficult are headers to do?
'13 SS L99
LTs, full exhaust, K&N cai, Diablo tuned
Jack13SS is offline   Reply With Quote
Old 03-05-2016, 05:03 PM   #11
snarky
ultracrepidarianism
snarky's Avatar
Drives: '14 1SS/RS/1LE/NPP '18 Accord Sport
lolz i used to push mine around with the old corvette. turns out it was the smooth garage concrete no likey. the driveway a bit rougher = no problem.
snarky is offline   Reply With Quote
Old 03-05-2016, 05:57 PM   #12
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
Not too difficult as long as you take your time. FYI auto parts stores rent torque wrenches so you can torque the bolts to 10 ft/lbs and then 18 ft/lbs starting at the center and working your way out.
OP, let me know how it works when you pull off of the ramps. I've always been scared to go up on the front end with them because of how badly they slip out from under the rear end when coming down.
Check out my build thread
Old 03-05-2016, 06:37 PM   #13
Avenging Orange
Avenging Orange's Avatar
I bought a cheap roll of rubber cabinet liner and cut it to fit under the ramps. Keeps em from sliding out.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 03-05-2016, 06:54 PM   #14
8balldeluxe
Drives: 2010 Camaro SS Victory Red
Wasn't that a tight fit to put headers on?
Speed Engineering Headers w/ Texas Speed HFC's ~ Flowmaster 2 1/2" cat back w/Flowmaster Super 10's ~ Cold Air Inductions Intake w/ Scoop and WW relocate ~ VMAX CNC Spiral PTB ~ Cross Drilled and Slotted Rotors w/Hawk pads ~ ZL1 Spoiler ~ SCTX4 RDP Tuned
8balldeluxe is offline   Reply With Quote
