Old 03-05-2016, 03:26 PM   #1
SantosNL
Drives: 2012 Camaro 2SS
Turbo 1/4 results?
Can anyone chime in on there 1/4 results with there turbo systems and supporting mods and if they were a6 or m6
SantosNL is offline   Reply With Quote
Old 03-05-2016, 04:10 PM   #2
bcguy
bcguy
bcguy's Avatar
Drives: 2011 ss/rs m6
Check out the fast lists and that should give you a better idea
Agp 62/66 ,lsx 427. , Callie's ,diamond ,all pro ,American racing ,I'ds130s,102 intake and throttle body,etc .fore triple , Turbo 400 level 5 , b and m pro , dss carbon fiber , dss ford 9 inch with strange pumpkin,3.73 ratio,1400 hp axels,boost and air fuel pillar guages. Weld rts 17x10 and 17x4.5 with m and h drag radials and skinnys
bcguy is offline   Reply With Quote
Old 03-05-2016, 04:20 PM   #3
Unreal
Drives: 2006 Z06
That list is SOOOO out of date.
I know Kevin ran 10.8@135-136. L99, AGP kit, meth, 18" drag radials. Thats it.
Another local customer went 9.2@156 first and only pass since he got booted for no safety stuff. 427, 4l80, twins.
Nick
Corvette Z06 -1200ish rwhp
Old 03-05-2016, 05:39 PM   #4
flyer08
Drives: 2010 2SS/RS
Not out of date if they dont post
flyer08 is offline   Reply With Quote
Old 03-05-2016, 09:11 PM   #5
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
There's a bunch of fast turbo Camaro's out there. Only a couple on here that are quick in the quarter.
Trackman is offline   Reply With Quote
Old 03-05-2016, 11:28 PM   #6
kevin87turbot
kevin87turbot's Avatar
Drives: 2012 Camaro 1SS with Turbonetics
I've taken my out a couple times. My best, so far, is a 10.53 at 130. Turbonetics kit, still at 8 psi. It's an automatic car.
2012 1SS...in the 10's...but not fast enough yet.
kevin87turbot is offline   Reply With Quote
Old 03-05-2016, 11:49 PM   #7
SingleT
Drives: 2015 2SS
That's impressive...
SingleT is offline   Reply With Quote
Old 03-06-2016, 01:14 PM   #8
robbiegordon
Robert
robbiegordon's Avatar
Drives: 2011 Summit White SS LS3
was gunna take the car out this weekend for test/tune but everything was delayed a week due to weather.. maybe heading out next weekend if we can get the weather track prep.. ill post my results once i can though..
Turbonetics T76 10psi with aem truboost controller, 231/239 115 LSA Comp Cam, adm fpcm, zl1 pump, Tr7ix plugs, 3.91/1LE Gears,Melling Oil pump, custom intake, catless midpipes, powerbond 25% underdrive, PFADT Aluminum subframe bushings, 1.5 inch drop, PFADT sway bars, BMR; sub frame connectors ,Trailing arms, Toe Rods, strut tower brace and rear diff bushings, Hurst short throw shifter and line lock,dyno #s TBD, , tuned by Pat G tuning
robbiegordon is offline   Reply With Quote
Old 03-06-2016, 01:20 PM   #9
bayarea408
bayarea408's Avatar
Drives: T
pump gas or E85?
What boost controller did you pick to use?
bayarea408 is offline   Reply With Quote
Old 03-06-2016, 10:24 PM   #10
kevin87turbot
Originally Posted by bayarea408 View Post
pump gas or E85?
It's still on pump for now. I was just on the springs last time.
I just installed an Innovate BC and an Alky Control kit last week. I'll bump up the boost soon.
Old 03-07-2016, 12:09 PM   #11
BradySS
Drives: 2010 Camaro 2SS
That's one of the better times I've seen with the Turbonetics kit. What else you got in your setup? Gear, stall, motor etc.
BradySS is offline   Reply With Quote
Old 03-07-2016, 12:36 PM   #12
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
Best I've done is 11.279 at 127 (1.75 60'). The DA was 7886 and FWIW using the online calculator estimates 10.789 at 132. I was spinning my DR's all the way through first gear so it would surely be faster hooking. Trying better tires next season.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 03-07-2016, 06:05 PM   #13
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
What's your rwhp at 8psi??
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 03-07-2016, 06:49 PM   #14
kevin87turbot
It's still stock 3.27 rear and stock axles. The trans is stock, but has the TCI triple disk converter and a Lokar dipstick. The converter alone was worth nearly 9 tenths. When I first installed the turbo kit, it would touch the rev limiter on both the 1-2, and the 2-3 shifts. It didn't matter where I set the shift points and rev limiter. Long story short, the Lokar dipstick, and over-filling the trans by 1 qt fixed all of that. It seems funny, but that 1 qt of fluid was worth .25 second on my car.
The engine is mostly stock, but has DOD Delete and a mild 224/225 .610/.605 114LS cam and matching springs.
