Old 03-06-2016, 04:30 PM   #1
hou30guy
Drives: 2011 convertible 2ss/rs
anyone installed a transmission and or oil cooler on the ss
Anyone install these and have good mounting locations
hou30guy is offline   Reply With Quote
Old 03-11-2016, 10:22 PM   #2
scv_guy
scv_guy's Avatar
Drives: 2010 Camaro SS
Here's my transmission cooler install
scv_guy is offline   Reply With Quote
Old 03-15-2016, 04:40 PM   #3
ticowarbird
BOHIC
ticowarbird's Avatar
Drives: 2010 Camaro SS "Enola"
Here's mine
What else can I do to my Camaro?
ticowarbird is offline   Reply With Quote
Old 06-29-2016, 08:49 AM   #4
hou30guy
Nicccce thxs
Old 02-23-2019, 10:24 AM   #5
HOPPER5
Drives: 2012 LS2
If someone is fouling around with a tranny cooler could you type in the diameter of the transmission lines so I can get started ordering AN fittings.
My car's in storage and even the dealer couldn't tell me or the only transmission shop around didn't know.
Plus if anyone with better knowledge on coolers could tell me if this cooler I got kicking around which is a stacked plate 15-Row cooler but only with 3/8" npt fitting openings. worth putting in? or get one with a 1/2" npt fitting openings.
Thanks in advance for any help
HOPPER5 is offline   Reply With Quote
Old 02-23-2019, 10:42 AM   #6
SS Performance
SS Performance's Avatar
Drives: 02 Camaro B4C
I went with this one.
https://www.phastekperformance.com/2...ion-cooler.htm
Might not be as big as what you are looking for. The nice thing about it is it uses the factory style connections to connect to the existing trans cooler lines. I wasn't impressed by the mounting brackets so I made my own.
A man's garage is his castle
1969 Camaro SS
1970 Camaro SS
2002 Camaro B4C
2014 Camaro SS Dedicated Track Car
2015 Camaro 1SS 1LE
2008 HHR SS
1996 Silverado Crew Cab Long Bed Dual Rear Wheel
SS Performance is offline   Reply With Quote
Old 02-23-2019, 08:21 PM   #7
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
They all will require some type of bracket fabrication FYI.
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 02-23-2019, 09:42 PM   #8
hammdo
'It's an experiment'
hammdo's Avatar
Mine:
https://www.camaro5.com/forums/showp...postcount=1702
Oil and trans...
-Don
747 RWHP 794 RWTQ
Old 02-23-2019, 10:41 PM   #9
Vegas Bound
Drives: 2013 Sparkly Red One
Remove the crash bar, gives a lot more room. I have a trans cooler, oil cooler and 4 core heat exchanger in front of my radiator.
Vegas Bound is offline   Reply With Quote
