Old 03-07-2016, 03:17 AM   #1
Tim14ILE
Drives: 2014 Camaro SS 1LE
Feeler 2014 2SS 1LE Black
The car has 4,700 miles on it roughly. I was building this to turn it into a drag car so I didn't shy away from buying the best. Car doesn't have sun roof or Recaro seats, but all other opitions are in it. I have included on picture and the build list. If you build a motor for this car and put a cage in it you could run 9s all day long. I have a little over 30k in parts in it. I am looking for $48k. I can email you the build sheet that is easier to read than the copy and paste of it.
Engine: ADM Cold Air Intake Sealed $375.99
Nick Williams 102mm Throttle Body $629.95
FAST Intake Manifold $799.99
2014 ZL-1 Low Mile Injectors $180.00
Injector Flow Testing Highest Flow on #7 & #8 $79.99
Lingenfelter 160 degree thermostat $24.95
Heads milled 0.40 $80.00
Holley Black Valve Covers $187.95
BTR .660 Springs $299.99
BTR Push rods $109.99
GM Head Bolts & Assorted Gaskets $119.99
LG Motorsports G6X3 Cam $599.99
PB 25% Underdrive Pulley $230.95
Katech Billet Belt Tensioner $119.95
MSD 2 Step Clutch Micro Switch $199.99
Hurst Line Lock $204.95
Nitrous: Nitrous Outlet 102mm Plate System $844.99
Nitrous Outlet Purge System $119.99
Nitrous Outlet Fuel Cell $899.99
Nitrous Outlet Rear Hatch Bottle Mount $149.99
Nitrous Outlet Bottle Heater w/ Pressure Switch $199.99
Nitrous Outlet Bottle Blanket $49.99
Nitrous Outlet Extra 10lb w/ Gauge $219.99
Nitrous Outlet Center Console Switch Plate $69.99
NOS Progressive Mini Controller $265.95
Exhaust: B&B Exhaust 1 7/8” headers $1099.99
Header Thermal Coating $280.00
B&B Exhaust 3” Fusion Cat Back w/ & w/o Cats $1799.99
Innovate Motorsports LC-2 Drivers Collector $149.99
Clutch: LT1-S Organic Triple Disc - Rated at 1000 RWHP/RWTQ $1899.99
Tick Performance Stainless Braided Clutch Line $129.99
Monster Billet Release Bearing Support $79.99
Monster 36” Remote Bleeder $39.99
Transmission: Tick Performance Level 3 TR-6060 Rebuild 700RWTQ and up $3199.99
MGW Short Throw Stock Boot & Ball $399.99
Driveshaft: Driveshaft Shop 3.5” Aluminum $899.99
Rearend: Lingenfelter Camaro SS 9.5 Inch Differential Preload 4.10 $4975.00
Bladder: Lingenfelter Differential Vent Bladder Kit $129.99
Axles: Driveshaft Shop HD 1400 HP Axles $1499.99
Extra set of axles 0 miles on them $1499.99
Suspension: BMR Subframe Connectors $319.95
BMR Tunnel Brace $49.95
BMR Driveshaft Loop $129.95
BMR Toe Rods Non-adjustable $89.95
BMR Lower Control Arms Non-adjustable $369.95
BMR Trailing Arms Non-adjustable $109.95
BMR Extreme Rear Anti-roll Bar $389.95
BMR Front 1” Springs $119.99
BMR Rear 1.4” Springs $129.99
BMR Rear Cradle Bushing Kit $179.95
BMR Differential Bushing Kit $39.95
BMR Outer Trailing Arm Bushing Kit $19.95
BMR Upper Control Arm Inner Bushing Kit $59.99
Additional: HP Tuners Pro w/ 4 Credits Remaining $649.99
Weld RT-S Front 18”x5.5 Polished Aluminum w/ Tires $850.00
Weld RT-S Front 17”x10” Polished Aluminum $944.26
Hoosier 28”x10”x17” Slick $443.94
Front & Rear Black Bow Tie Not Installed $178.62
Tim14ILE is offline   Reply With Quote
Old 03-07-2016, 05:26 AM   #2
snarky
ultracrepidarianism
snarky's Avatar
Drives: '14 1SS/RS/1LE/NPP '18 Accord Sport
very nice. GLWS.
snarky is offline   Reply With Quote
Old 03-07-2016, 07:38 AM   #3
Tim14ILE
Thank you very much
Old 03-07-2016, 08:08 PM   #4
Dutchman427
Drives: 2012 ZL1 #1329 M6
Very nice build man! Good luck with the sale.
Dutchman427 is offline   Reply With Quote
Old 04-18-2017, 11:52 PM   #5
Tim14ILE
Bump really want to get this moved. Send me reasonable overs. I have added BMR engine mounts and stiffer trans mount.
