![]() Drives: 11 IBM n White 2SS/RS M6 Join Date: May 2011
Battery replacement options
Looking for a few options on Battery replacements for my 2011 SS
Feedback wanted!! Ready set Go!!
Black CIA -Powder Coated Red Air Scoop - Vmax Ported Throttle Body - Ceramic Coated Dynatek Headers - High Flow Cats out thru factory Cat Back - JRE rough idle cam package - Trunion Upgrade - Valve Springs - Hardened Push rods - 3 bolt timing gear - SLP Under drive pully- Washer bottle relo kit - Hurst Short Throw Shifter with updated pin bushing from C5 member NH-SS - IdealG's improved Master Cylinder - GTO Clutch reservoir - L99 Brake Reservoir - Stainless Braided clutch line - wrapped up with a JRE Tune My SS layed down 462 hp on JRE's Superflow Dyno
my original lasted over 5 years, so I went back with another from the dealership parts dept. Think it was around $160
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
My original lasted 6 years. I got a Sears replacement for $220.00. Never paid so much for a battery.
El Duderino
INTERSTATE!
You should call their factory store because many times they will have a really good deal on a blem (something wrong with the label etc.) Interstate All Battery Center Address: 30 Nashua St. Woburn, MA 01801 Call: 781-932-0076 Hours: Weekdays: 8:00 AM - 5:00 PM Saturday: 8:00 AM - 1:00 PM Sunday: Closed
I have had 2 original batteries in the past 6 months put in my '11. Each went bad in 3 months almost to the day and the car would not start if it sat more than a day. Finally broke down and put in an Optima, no problems since.
#6 |
El Duderino
Optima doesn't make a direct fitment replacement. Which Optima are you using?
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 Red Hot LS3 Join Date: Oct 2014
#8 |
'It's an experiment'
I actually bought a Duracell ultra platinum. They do have a gold version..
https://www.batteriesplus.com/batter...0cca/sli94ragm 10% off code CDP10011 Not the cheapest, but cranks great... 4 year free replacement, no prorate... -Don
747 RWHP 794 RWTQ
#9 |
I run 2 catch cans...
I just replaced my stock one with this AC Delco AGM: http://www.amazon.com/ACDelco-94RAGM...s_a_1_1&sr=8-1
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more: . |
#10 |
El Duderino
Lots of brands, but only three makers in the US.
Delphi, Exide and Johnson Controls. That's it.
#11 |
![]() ![]() ![]() Drives: 2010 2SS/RS M6 Black on Black Join Date: Jan 2010
My original lasted six years, just replaced it with a Bosch (Exide) from Pep Boys. Chose it because it is a glass mat. So far so good.
Meh
#12 | |
![]() Drives: 2010 2SS/RS 6spd LS3 Join Date: Jan 2015
#13 |
![]() Drives: 2011 Cyber Gray 2SS 6 speed Join Date: Jan 2012
I went with the stock AC Delco for a replacement for my 2011 SS LS3. I got it at my local chevy parts department. It is vented and obviously fits and has the right CCA. I vote for the stock replacement.
#14 |
Trust No One!
Drives: 2010 SIM 2LT/RS Join Date: Oct 2014
I just replaced my original OEM one with this one:
H7-AGM Autozone |
