03-07-2016, 02:04 PM | #1 |
Drives: 2018 Charger SRT 392 F8 Green Join Date: Aug 2010
Removing front bumper
Hey everyone I did try searching but there seems to be some sort of error popping up.
Anyway, is there a link to any step by step instructions on how to remove the front bumper of a 2010 SS? It looks pretty straight forward but I don't want to assume anything. Looking to install a heritage grill. Thanks. |
03-07-2016, 02:05 PM | #2 |
Drives: 2013 Camaro 2SS/RS M6 Join Date: Feb 2013
2013 Black / Black Camaro 2SS/RS M6 w/Magnuson TVS2300, ZL1 Fuelpump / ADM FPCM, NPP Exhaust, Cold Air Inductions CAI w/ Scoop, Elite Engineering Catch Can, VMAX Ported TB, OEM 1LE Front Splitter, AAC Ghosted Side Markers, Dropped on BMR Split Drop Springs Build#24869 |
03-07-2016, 02:07 PM | #3 | |
03-07-2016, 02:10 PM | #4 |
I used the same video. It was very helpful. Spent more time going back to watch the video (as I went along) than it actually took to remove the bumper.
Pulling the grill out of the back of the bumper is a pain!
Taco's 2014 SS
Mods: 417 Stroker | CAI | Bo's PTB | Kooks LTs | Flowmaster Outlaw Catback | Night Fury Cam | Powerbond UDP | Apex Catch Can |PRC Ported Heads |FAST 102 Intake |Suspension Crap| Built by J-Rod. |
03-07-2016, 02:12 PM | #5 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
Used this when I did my SS. It's mostly accurate.
03-07-2016, 03:40 PM | #6 |
Drives: 2016 SS Join Date: Jun 2011
By "mostly accurate" he means they left out "drink a beer" between each step shown above.
03-07-2016, 03:44 PM | #7 | |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
Yep... same set of vids I used to replace my bumper! |
03-07-2016, 05:57 PM | #8 |
Stovebolt BluFlame 6
Drives: '12 2LT/RS, IBM; '20 Traverse Prem Join Date: Oct 2011
I used this as well. Tried to get smart and not take the wheels off; took me an extra hour instead of saving time.
03-07-2016, 08:34 PM | #9 |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
Spike III
Jeff it was most likely Beer & a box of wine. It's hard to figure which one he likes more. So he just drinks the wine and uses the beer for a chaser. I know I would.
03-08-2016, 01:38 AM | #10 |
to get the 3 bolts in the fender well bend the inside fender and stick it in between the rotor and backing plate. wont damage anything and it stays out of your way. remove the 2 push pins to do it.
03-08-2016, 07:35 PM | #11 |
Drives: 2010 2LT/RS Join Date: Mar 2015
Is there a place on the heritage grill where a badge could be placed in the same position as the factory grill? Say for example SS or RS?
03-09-2016, 02:42 PM | #12 |
Started#gottalovethatblue
Yes, but you have to buy a bracket for it.
03-09-2016, 03:43 PM | #13 |
Open the hood 1 bolt on each end on top of the Fascia 6 push pins. Underneath each side 3 hex head screws. 1 screw on each side just underneath where the side marker light is. When you have these all out pull on the fascia slowly don't pull it off all the way yet. On the passenger side is the electrical plug that goes to all the lights on the fascia after you unplug it. Lay a blanket down first. The fascia is not heavy just awkward. When you go to put it back on take your time there is 3 guide pins on each side to help you align it in to the holes. Good Luck
03-09-2016, 07:43 PM | #14 |
