Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Suspension / Chassis / Brakes
Old 03-07-2016, 07:00 PM   #1
12white_SS
Drives: 2012 white 1SS, 2011 silver 2LT
2010-11 camaro part out (2lt)
Have an extra parts car with a lot left on it. Just trying to put money together for the other camaros. May consider trades for some SS parts. Just let me know what you have.
12white_SS is offline   Reply With Quote
Old 03-07-2016, 08:15 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Need a wiper cowl an trunk corners...
Orange Krush II
Old 03-07-2016, 10:42 PM   #3
12white_SS
Sent you a pm
Old 03-08-2016, 06:17 PM   #4
NOVAK
NOVAK's Avatar
Drives: 2015 ZL1
Need the rear right strut assembly, upper and lower control arms, knucke/hub, basically everything that attaches to the crossmember on the rear right side. Don't need the rotor or caliper.
NOVAK is offline   Reply With Quote
Old 03-09-2016, 07:58 PM   #5
12white_SS
Pmed you, to anybody wanting stuff let me know what you think is fair and we will go from there. I'm not going to keep the car forever just to part out every last thing.
Old 03-20-2016, 10:58 PM   #6
12white_SS
Bump
Old 03-25-2016, 09:16 AM   #7
Omega
Drives: G8
So you have the complete rear cradle assy?
Omega is offline   Reply With Quote
Old 03-25-2016, 10:37 AM   #8
BronxxBombers213
BronxxBombers213's Avatar
Drives: 2010 Camaro 2SS RS
I need the two rubber caps/grommets from either door that cover the mirror bolts.. One of each, round and rectangle
BronxxBombers213 is offline   Reply With Quote
Old 03-26-2016, 09:41 PM   #9
Rocky1974
Rocky1974's Avatar
Drives: 2010 RJT 2SS M6 Camaro
What color is the parts car? Is it a RS?
2010 RJT 2SS M6, Kooks Long Tubes, NPP Exhaust, CAI Cold Air w/Jannetty Scoop, RotoFab Washer Bottle, Elite Engineering Catch Can, MGW Shifter w/ZL1 Shaft and Knob, 2015 SS Sedan Steering Wheel and Air Bag, 2012 Heater Hose Conversion, 2012 Power Seat Conversion, RS Head Lights,Gen5DIY RS Conversion Harness, LED Fog Lamp Bulbs, Backup Camera Kit, NLP Spoiler, SLP Splitter, ZL1 Rockers and Diffuser, Color Matched Shark Fin, RS Roof Mouldings, Painted White Stripes, WCC LS3 Emblems, Heritage Grille and Blacked Out Tail Light Panel w/Retro SS Emblems, 416 RWHP, 411 RWT, Tuned by BlueCat.
Rocky1974 is offline   Reply With Quote
Old 03-28-2016, 06:46 PM   #10
KidKilowatt
KidKilowatt's Avatar
Drives: 2011 Camaro 2LT RS
Need the hood hinges and latch mechanism. Have original struts/springs front and back?
2011 LLT RS Black on Black Loaded. [x]Showstopper 45th Anniversary inspired Camaro RS Stripes, [x] MPD1 Spoiler, [x] GM Heritage Grille. [x] Removed RS and Bowtie Emblems. [x] 30% Tinted Headlight Armour DRL's. [X ] Ruff Racing R954 Wheels [X] Solo Cat Back Mach X-LLT Exhaust [X ] Vmax Ported throttle body [x] Halo SC Reverse Hood Kit [x] Showstopper Painted, Modded Engine Cover [x] Cold Air Inductions CAI [x] Tinted Tails and Black Bezels [x] Megan Racing Street Series Coilovers [x] Belltech F&R Sways
Check out my build thread!
http://camaro5.com/forums/showthread.php?t=212178
KidKilowatt is offline   Reply With Quote
Old 04-05-2016, 10:51 AM   #11
JohnZ
JohnZ's Avatar
Drives: 2010 Camaro 2LT V6
Can you pm for the 2 front sets of little screws that hold the plastic wheel well arches in place? Also, the mounting hardware for the stock washer fluid resevoir?
Injen CAI, V-Max Throttle Body, Rx 25mm Iceolator, Rx 10mm Plenum Spacer, Mace Ported Manifold, ARK N-II Catback, Trifecta Tune, Rx Catch Can.
BMR Bushing Inserts,Pedders Radius Rod Inserts, Pfadt Sway Bars and Endlinks, LSR Front Subframe Brace
SS Brembo Brakes, Racing Brake Stainless Lines
JohnZ is offline   Reply With Quote
Old 04-06-2016, 10:29 AM   #12
12white_SS
Sorry everyone I was away for a bit while we were moving but I think I've pmed everyone, if I messed you message me
