Old 03-08-2016, 11:21 AM   #1
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
What Boost Will I Be At After Cam Install?
Max boost i was at 10.9 on my last dyno pull. What boost will i be at after my BTR Stage 3 PD cam install?
I ask because i am trying to consider if i should pick up a smaller pulley or not yet. Unsure if i want to run whatever boost my cam gives me until my e85 system goes in?
Nighthawk89 is offline   Reply With Quote
Old 03-08-2016, 11:31 AM   #2
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
Save your pulley money and put it towards axles and a proper tire so you can HTFU and not just roll race me, Devin lol
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq
Jeff_SS is offline   Reply With Quote
Old 03-09-2016, 07:54 AM   #3
old motorhead
Drives: Maggie blown LS3 vette
With an 81mm pulley on my Heartbeat, I see 9.5 to 10psi. My cam, at 224/234 116+2, is smaller than BTR's stage 3. I'd guess your boost would be slightly less than mine with the same size blower pulley. That's assuming you have LT's and a free flowing exhaust.
old motorhead is offline   Reply With Quote
Old 03-10-2016, 01:33 AM   #4
Nighthawk89
I am running the 84mm pulley and I'm running 10.9 max boost without new cam and yes i am running LT's no cat's and the corsa ZL1 3 inch quad tipped exhaust. Should be pretty free flowing. Well see i guess. I may stay at same pulley size or go one size down..
Old 03-10-2016, 07:14 AM   #5
old motorhead
If would be interesting to see before and after dyno numbers. See how much just a cam swap would be worth. You might consider a meth kit if you're stuck with that 91 octane California skunk piss gasoline. Especially if you pulley down another notch.
Old 03-10-2016, 11:02 AM   #6
Nighthawk89
I think thats what i may do. I considered meth but I am going to flex fuel route to see what kind of gains that provides first.
