Old 03-08-2016, 08:46 PM   #1
silkrckt
silkrckt's Avatar
Drives: 2017 Garnet Red 1LE
Fuel system first?
Can I upgrade my fuel system first prior to doing a twin turbo build without any tuning? I wanted to do the AGP kit and twin pump they offer. I am planning on moving to another state and want to hold on to some funds in case. Thinking to knock out the fuel side first, then the system later.
I was also thinking about doing the trap door method for the pump. any guidance there?
thanks everyone.
New Camaro --- 2017 SS 1LE Garnet Red -stock
Last Camaro --- 2014 2SS || 6 speed || NPP || Kooks 1 7/8 LT +Cats || Apex Catch Can || BW PTB || CAI induction || 12.99 @ 111 stock tires, 2.1 60'
Old Camaro --- 94 Z28 Vert-- Miss it.
silkrckt is offline   Reply With Quote
Old 03-08-2016, 09:29 PM   #2
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
I don't have any FI currently but I can imagine you can upgrade the fuel side first. You have to tune the fuel system to work. You cant throw ID850s or whatever injector in a LS3 and it work 100% correctly. Same goes for the fuel pumps.
My friends Saturn Ion Redline he tried doing that. He put 60lb injectors (stock is 42lbs) in without a tune, it ran and drove but not very well.
Old 03-08-2016, 09:51 PM   #3
silkrckt
silkrckt's Avatar
thanks, I wouldn't touch the injectors. They come with the AGP kit. Just the pump and any lines required. I don't know if it requires a different controller or uses the stock control module.
Old 03-09-2016, 07:09 PM   #4
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
When you increase your fuel pressure, you will run rich, so yes, you will need a retune.
Now just how rich you will run I dont know.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 03-09-2016, 07:16 PM   #5
Unreal
Drives: 2006 Z06
Keep money in account, and deal with it later. No point in doing it early, just adding cost/complexity.
Nick
Corvette Z06 -1200ish rwhp
Old 03-10-2016, 10:38 AM   #6
silkrckt
silkrckt's Avatar
Thanks guys. Just eager to get something going toward the twins. I missed the awesome deal on the cast wheel turbos since the decision to move came during the winter. I'll hold off and get everything squared away at once.
