Old 03-09-2016, 01:01 PM   #1
BAD DAB
BAD DAB's Avatar
Testing battery?
My Camaro is almost 6 yrs old. I see where some members have already replaced 4 and 5 year old batteries. Can the battery be tested from under the hood or should it be tested directly from the trunk?
Old 03-10-2016, 04:50 PM   #2
Dimitrim
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1
Most auto parts places like Kragen or Napa will do a load test for free. Load test is the best way to test a battery. It only takes a few minutes. Just leave the battery in place, turn the engine off.
If you need to replace the battery I would get a AGM ( All Glass Matt Battery). They are great. Interstate Batteries make a real affordable great one.
Dimitrim is offline   Reply With Quote
Old 03-10-2016, 05:53 PM   #3
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Under hood is fine
camguynj is offline   Reply With Quote
Old 03-10-2016, 07:37 PM   #4
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
A load test is best, as stated and must be done at the battery for best results. Not sure it can be done anywhere else.
HOJO is offline   Reply With Quote
