Old 03-10-2016, 12:33 AM   #1
bionick
bionick's Avatar
Drives: 2010 2SS/RS M6
100 shot
Mods in sig.
Want to run a 100 shot nitrous outlet kit.
I plan to get the kit, switch panel, stage 3 accessory kit, and the LNC-2000 to pull the timing. Is there anything else I need to do to be "safe" with the tune, etc? New to this area and want to do it right and as safe as possible. Any nitrous experts please give me your opinion. I appreciate it!
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
bionick is offline   Reply With Quote
Old 03-10-2016, 01:48 AM   #2
MurderMaro
MurderMaro's Avatar
Drives: '13 Black 2SS 1LE
I recommend colder plugs like the BR7EF and a fuel pressure safety switch which you can run in conjunction with a fuel pressure gauge. Also look into an air/fuel ratio gauge for monitoring lean spikes to prevent detonation.
MurderMaro is offline   Reply With Quote
Old 03-10-2016, 03:38 AM   #3
damian559
damian559's Avatar
Drives: 2015 1SS, 1LE, Recaro, NPP
Window Switch/WOT switch
Stand alone fuel cell
colder plugs (NGK BR7EF)
Wideband gauge
Purge kit
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor)
647 RWHP 723 RWTQ (150 Shot)
12.1 @ 117 (Motor)
11.7 @ 129 (Nitrous)
Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports
Youtube Channel:
Click Here
damian559 is offline   Reply With Quote
Old 03-10-2016, 08:55 AM   #4
bionick
bionick's Avatar
Forgot to add, I do have a wideband in the car and currently I have NGK TR6 plugs. Eventually I would like to get the nitrous outlet dedicated fuel system but if it's not entirely needed for a 100 shot then I will hold off on it. Will my current tune need to be adjusted or is the LNC-2000 all I'll need?
Old 03-10-2016, 08:59 AM   #5
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Lnc2000 is all you need to pull timing
A/f ratio on nitrous can be adjusted by fuel jets in the plate
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 03-10-2016, 11:40 AM   #6
damian559
damian559's Avatar
Yeah you'll be fine pulling fuel from the rail for a 100 shot, but you'll want to up the shot very soon after. No, the LNC-2000 is the only thing you'll need, but you should put it on the dyno to check AFR still. Lastly, do NOT use those TR6 plugs, nitrous and projected tip plugs do not go well with each other.
12.1 @ 117 (Motor)
Youtube Channel:
Click Here
Old 03-10-2016, 11:43 AM   #7
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr
Wideband gauge
Purge kit
Look into the NOS mini controller instead of the window switch. Its nice to be able to adjust for traction conditions.
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS.
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47**
Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver
Daily Driver 2021 BMW M340i Xdrive
IneedAZ is offline   Reply With Quote
Old 03-10-2016, 12:30 PM   #8
damian559
damian559's Avatar
He shouldn't have traction issues with a 100 shot unless he's on some shitty tires. My 20" Mickeys hold up no problem with my 150 shot
12.1 @ 117 (Motor)
Youtube Channel:
Click Here
