03-10-2016, 12:13 AM | #1 |
ported throttle body yes or no?
i have studied up on this and just get more confused, some say it's great!! 10-15 horses. some say it kills the mid range and others have had tuning problems with them, so enlighten me, get 1 and what brand or stay stock. thanks
03-10-2016, 01:13 AM | #2 |
Drives: 2013 2SS (sold) Join Date: Jan 2016
Get it! Won't add much hp but throttle response is much better. You'll definitely notice a difference when you drive it. Get a Bo White or Vmax
Track Parts/Stock Parts Part Out http://www.camaro5.com/forums/showthread.php?t=515534
03-10-2016, 04:36 AM | #3 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
Maybe 3 hp...maybe. I have the vmax it's popular here. I really didn't notice a huge improvement in th th throttle response. There was a difference for sure. Bo white has good reviews so does vmax. My vmax has been trouble free since the install.
03-10-2016, 04:53 AM | #4 |
Started#gottalovethatblue
I've heard up to 5 rwhp max, but like rontammy0 said 3 is probably more realistic, at most. It isn't a power gain that you're after with a ported throttle body, it's the throttle response. If you have a L99 a ported throttle body is a must have. I had Bo White do mine and I've been very pleased with it. As for tune trouble, that sounds quite ridiculous but I'll let you know in a month when my tune gets applied.
03-10-2016, 05:40 AM | #5 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
if I say it gives you 50+ hp, now you can say you heard it gives at least 50 more hp?
Not going to get any more HP out of it. What you will see is a better throttle response when moving from a dead stop, or accelerating hard. |
03-10-2016, 06:47 AM | #6 | |
Ported, absolutely yes. Like said above, 3-5hp. (There's a thread in here somewhere where I believe Bo White did dyno pulls and shared the results.) Either Vmax or a Bo White TB. 102mm TBs, as in Nick Williams TBs, have problems tuning. Some people get these when they add a 102mm FAST intake manifold. (That is where your loss of midrange power will come from.)
Taco's 2014 SS
Mods: 417 Stroker | CAI | Bo's PTB | Kooks LTs | Flowmaster Outlaw Catback | Night Fury Cam | Powerbond UDP | Apex Catch Can |PRC Ported Heads |FAST 102 Intake |Suspension Crap| Built by J-Rod. |
03-10-2016, 07:42 AM | #7 |
Drives: 2015 Camaro 2SS Ashen Grey Join Date: Mar 2016
I installed the VMAX about three weeks ago. As described above, throttle response from dead stop and when accelerating is more pronounced. I did throw a P1400 code after about 1 week, but then I disconnected the throttle body harness and replugged in and the code cleared. We will see if it comes back. I also installed a CAI (Volant) at the same time. The install is very easy.
03-10-2016, 07:52 AM | #8 |
Maybe....
03-10-2016, 12:06 PM | #9 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
A worth while mod , and you will feel the diff in throttle response . And Bo's ported TB is with out a doubt the best way to go .
OLD GUY FLYING FAST AND LOW
03-10-2016, 04:10 PM | #10 |
Agreed!! Like Bo posted above, maybe 1 million horsepower!
03-10-2016, 04:31 PM | #11 |
Banned
Drives: Camaro Join Date: Mar 2013
No
03-10-2016, 09:03 PM | #12 |
Drives: 2018 camaro 1ss 1LE Join Date: Apr 2013
GET IT. BO WHITE OR V MAX. GET THE VARARAM WEDGE TOO. you can feel the difference for sure.
03-10-2016, 09:51 PM | #13 |
Drives: 1969 Z28, 1982 Z28, 2014 SS/RS/1LE Join Date: Nov 2013
No matter of HP, throttle response. I have a Bo White. When I put it on, I didn't seem to notice a huge delta. But a few months later I swapped it back and put the factory TB back on. (I had a bad plug wire and was trouble shooting.) When I took it for a ride with the stock TB back on after months on the Bo TB...HOLY SMOKES could I tell the difference! It was huge. Made me a firm believer in the ported TB. Do it!
03-11-2016, 05:09 AM | #14 |
Yes, Bo White is what I went with and the difference with the throttle response is well worth it.
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
