Old 03-11-2016, 11:43 AM   #1
TheWood
Drives: 2013 SS
Which gauges?
Installing nitrous system next weekend. Smaller shot. Was donated a A-pillar gauge pod. So, i'm needing advice on what two gauges would be best to monitor the system. I was thinking either 2 aeroforce gauges, or a A/F with something help. Open to any suggestions.
TheWood is offline   Reply With Quote
Old 03-11-2016, 11:44 AM   #2
BRAVO 2SS
Aim Small...Miss Small
BRAVO 2SS's Avatar
Drives: 2018 ZL1 M6
Aero force gauges are amazing!
2010 Camaro 2SS/RS
BRAVO 2SS is offline   Reply With Quote
Old 03-11-2016, 11:57 AM   #3
MurderMaro
MurderMaro's Avatar
Drives: '13 Black 2SS 1LE
AEM afr gauge & fuel pressure gauge. You'll want to monitor any drop in rail pressure and afr ratio so you don't lean out and detonate when you're on spray. That's the set up I use on a 100 shot plate kit.
MurderMaro is offline   Reply With Quote
Old 03-11-2016, 01:16 PM   #4
hammdo
'It's an experiment'
hammdo's Avatar
I have duals and love them...
-Don
747 RWHP 794 RWTQ
Old 03-11-2016, 01:50 PM   #5
damian559
damian559's Avatar
Drives: 2015 1SS, 1LE, Recaro, NPP
I have the Innovate Motorsports PSN-1, it's both a wideband and bottle pressure gauge. It also monitors the AFR and if your car begins to lean out it will instantly cut off the nitrous.
https://youtu.be/RxjLe0UyJzs
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor)
647 RWHP 723 RWTQ (150 Shot)
12.1 @ 117 (Motor)
11.7 @ 129 (Nitrous)
Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports
Youtube Channel:
Click Here
damian559 is offline   Reply With Quote
Old 03-11-2016, 03:52 PM   #6
2SSLincolnSS2
SoCal
2SSLincolnSS2's Avatar
Drives: 2011 SS2
I have (1) Aeroforce (a must, it has many of the ECM's specs), and (1) AEM wideband failsafe (boost/AFR). The failsafe would be great for you because if the AFR goes lean, you can set the gauge to turn off the nitrous....
<a href=http://www.camaro5.com/forums/picture.php?albumid=9810&pictureid=82873 target=_blank>http://www.camaro5.com/forums/pictur...ictureid=82873</a>
2SSLincolnSS2 is offline   Reply With Quote
Old 03-11-2016, 09:05 PM   #7
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
aem wideband 02 and aeroforce scan gauge
monitor a/f ratio with the wideband and knock (plus everything else) with the scangauge
two must have gauges imo!
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 03-11-2016, 09:42 PM   #8
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Agreed.
gauges are still working great! Thanks
